I would be "restricted" to use it if the regulations "forced" me to do it.hardingfv32 wrote:As DRCorsa summarized and demonstrated:
"For the concave, downforce and drag levels are lower, there is the suction peak at the kink line and there is notably less downforce and stall after the kink line."
So why would you use what on the surface looks like an inferior roof (floor) shape?
I mean, if the regulations call for a very high roof angle when using a convex shape (small length and large height of throat), i would use the concave if this proved to be "less bad" in terms of stalling.
The convex throat in my analysis is really smooth because i didn't have to follow any rules. If the convex shape would have been much steeper, maybe thing would be reversed.
And if i could use the exhaust to reenergize the boundary layer and limit the negative effects of this stall then i would be happy at the end of the day.
Just have a look at how much lap times has been improved the recent years. In many circuits, the best lap time is similar to those during 2004 with those 3-litre super-powerful engines. And i really believe that the largest stake of improvement has been made due to aerodynamic developments rather that other factors (tyres, suspension etc).
