This should be easy and long.
Let's say, 2.5 seconds for 0-100 kph. We shall assume negligible drag with air, or, if you have figures for 0-50 kph or 0-20 kph, the better. I don't. I swear I won't change this value (2.5) as I write, value I haven't checked but took from the top of my head. Let's see where it takes us:
Acceleration = (100 / 3.6) / 2.5 m/s2 = 11.1 m/s2
Distance = (100 / 3.6)^2 / (2 * 11.1) m = 69.4 m
Mass = 600 kg
Force = 600 * 11.1 newtons = 6667 newtons
Work = 6667 * 69.4/1000 Kjoules = 463 Kjoules
Power = 463 / 2.5 Kwatts = 185.2 Kwatts
Power (hp) = 185.2 / 0.746 = 248 hp
First number: the power delivered to your a** is 250 hp.
To answer your question, we should sum the power dissipated on friction with air. From the 2.5 seconds I gave, we should discount the time the engine is idle because the pilot is changing gears. Can an F1 car reach 100 kph in first gear? I don't know. I assume you can.
Then, with:
Coefficient of drag = 1.0
Density of air = 12 kg/m3
Frontal area = 0.9 m2 (my guess)
Coefficient of rolling resistance = 0.012 (another, this time educated guess)
So:
Drag force = 1.0 * 12 * 0.9 / 2 * v^2 = 5.4 v^2 newtons
Drag power = 5.4 * (100/3.6)^3 / 2 joules = 57.8 Kwatts
Drag power hp = 57.8 / 0.746 = 78 hp
Rolling power = 0.012 * 600 * 9.8 * 69.4 = 4.9 Kwatts
Rolling power hp = 7 hp
Finally, second number:
Power to the wheels: 248 + 78 + 7 = 332.4 hp
Percentage of power to the wheels = 770/332 = 43 %
I think I have something wrong integrating the force over distance (maybe I did it over time?) to get the drag power, but you get the idea.
I would love for someone to correct this, as a mere 78 hp expendend on drag seem little at first sight. If you wish you can download these quick calculations
here and try with different 0-100 kph times, or, if you have the time, correct the suspicious drag power part.
If you a) have live data and b) analyze the sound of the engine, you can even get a curve of engine performace vs rpm. So I do not know how they keep these things secret...
You could do a little spying on the performance of F1 engines from the comfort of your own living room.
