xpensive wrote:Interesting scarbs, funny there is no ban on DLC, would you have any idea what the oppsite surface in the liner could be?
1) Although things do change, nickel/silicon carbide composite coatings (ceramic) were/are generally the best solution for the bore coatings. Have you heard of anything better being developed?
TiN coated compression rings being a very good match with nickel/silicon carbide composite. Anything new in this area.
2) I am not sure there would be any concern with the DLC piston skirt coating and nickel/silicon carbide composite cylinder walls, as under normal operating conditions they should never come in contact. It would be my understanding the the DLC would be concerned with reducing the friction caused by the oil film and/or use of lower viscosity oil in this area. Your opinion?
Brian
