Up for discussion are the 2012 nose regulations, there implications, and possible 2012 nose designs.
2011 Design:
![Image](http://img151.imageshack.us/img151/7966/2011standardnosedesign.jpg)
Very simple design, using a straight line underneath to continue the slope of the underside of the survival cell, which I'm fairly certain doesn't happen, but any curvature is slight on any noses of 2011 cars, so it'll do for a demonstration. Loads of room under the nose for air to pass, I'm unsure as to what the benefits of that are though.
Scarbs Design:
![Image](http://img859.imageshack.us/img859/8948/2012scarbsstylenose.jpg)
Whilst not exactly Scarbs' design at all, merely the shape he used on his blog to explain the 2012 regulations, I used the same survival cell shape, with the dash bulkheads in the same position as they are in 2011, and the front bulkhead at the highest it can be in 2012. This design has the lowest tip, the smallest area under the nose, and the largest area above the nose. I do think however with some clever shaping of the underside of the nose, we could see a design using this concept in 2012.
Piola Design:
![Image](http://img812.imageshack.us/img812/4613/2012piolastylenoseilleg.jpg)
A few weeks ago Giorgio Piola released a video explaining changes for 2012. He showed a nose looking like the one above. This is the only design I have down which is actually illegal in 2012. To make it legal it would have the lowest tip, and would have a really 'obese shape', as seen below. For this reason I doubt we'll be seeing it in 2012. (It's this way, because the front of the survival cell must be 275mm tall, even if the front is moved forward).
![Image](http://img829.imageshack.us/img829/526/2012piolastylenoselegal.jpg)
Table top Design:
![Image](http://img840.imageshack.us/img840/2887/2012tabletopnose.jpg)
This is basically the 2011 design, moved down 75mm, with some optimization, its the design I expect to see most of in 2012, but I could well be wrong.
N Smikle Design:
![Image](http://img.photobucket.com/albums/v626/nsmikle/2012nose.png)
With under nose optimization, raising the tip, this is the kind of design we're likely to see next year, although probably a little less 'extreme'.
