Why do they need tighter restrictions on the clutch control?
Brian
So,,,Launch control is permitted. hahahaBite point finder where brake pressure, wheel speed and driver clutch demand
safeguards are used.
So it should read as I have altered it,,,with a comma?Bite point finder where brake pressure, wheel speed and driver clutch demand,,
Yes that's what they do and the slow releasing paddle does the slipping for them... creates the slip and lack of tire spin and that supposedly will be gone.I wonder if they were using a predetermined clutch release rate at the starts. The driver just released the paddle instead of easing it out.
1) That is assuming a complete (100%) release of the clutch paddle by the driver. If the driver is controlling the % of release of the paddle/clutch below 100% then the time restriction does not come in to play.strad wrote:50ms?? Isn't that like real quick...like popping the clutch?
