Ferrari F2012 (pre-launch speculation)
Lorenzo_Bandini
Lorenzo_Bandini
Re: Ferrari F2012 (pre-launch speculation)
Dimi PAPADOPOULOS
According to Gazzetta dello Sport, Marco Fainello, Head of Vehicle Dynamics at Ferrari is on gardening and could he on his way to Merced ...
21 minutes ago
From Twitter
- From La Gazzetta dello Sport' on the 2012 Ferrari: Pull-Rod suspension, the pilots will go lower
- rear spoiler interim provisional front wing, xtraction of single channel internal heat, modifications of the nose, escapes defined area, storage rooms
- F2012 in February and in Melbourne with luck, will have changed more than 60% visibly
- the front wing will have some appendices are not reflected in the simulation, logical thing obviously
- from La Gazzetta article The nose shows changes on the outside not inside;)
- And nothing from the exhaust, is a simulation of something 'simplistic'. If you teach the diffuser off and let's go;)
- The wheelbase is maybe shorter front
- Venting heat from a single central hole
- DRS yet not finshed
- Stepped nose and front wing introduced in Korea will be more developed and certainly not 'simple' looking;)
Marco Alves
Marco Alves
MIKEY_! wrote:I would tell you that's a great help but unfortunately I don't speak Italian :lol:
Something about using pull-rod suspension like Red-Bull and being in a position to challenge Mclaren?
A driving position like McLaren.
aleks_ader
90
Lorenzo_Bandini wrote:Dimi PAPADOPOULOS
21 minutes ago
From Twitter
Notthing NEW! That we adready now, but anyway i m not sure if ferrari will use them... Maybe Bryne try other thig ("crazy floor diffuzor"about that we aldredy discuss)?
Lorenzo_Bandini
Lorenzo_Bandini
Thanks to saqi58 on Tifosiland Lounge for the translation of La gazzeta article on Ferrari 2012
In less than a month, we will be seeing a Ferrari, that has no ties with the past at the
Maranello unveilling, expected at the beginning of February.
Changes: There will be a number of changes starting with the external “dressing”,
even if initially the single-seater will be camouflaged, using the same wings that the
150' Italia ended the season with (numbers 1 and 9). Rather than predicting what
those changes might be, we chose to create a mosaic of the expected changes,
starting with those already simplistically applied to the 2011 single-seater, namely
the two regulations that will impact on all the cars as compared to last year’s
models, the height of the rear of the car, thus the height of the nose (2) and the
banning of the blown diffuser (6).
Diffuser: Previously banned, now subject to very strict electronic limits to avoid hot
exhausts, even when in low acceleration, Red Bull’s strength in 2011. Of the two
new regulations, especially the second, has influenced the rear aerodynamic
design, basically from scratch. It’s important to remember that the primary
objective of everyone in research is to find a solution that will not nullify the
advantages obtained in 2011 of the hot exhaust in the diffuser. In fact, the research
is concentrated on how to position and direct the residual effect blown, to render
the rear wings more efficient, comprised of two levels that are distinguishable.
Incline/heigh: The regulations restrict the exhausts in the area away from the
diffuser and rear (6) of the car, has left a certain amount of freedom (around 30' on
the longitudinal axis/side and 10' on the transversal) that will allow a notable
variation on the possible solutions for the rear wings. And the rear is exactly where
we will see different and unedited solutions.
Intake/Aspiration: The Ferrari (like the ToroRosso) introduced, since the Belgium GP, a new
group of diffusers which uses a sort of “lung” ventricle (5) that might guarantee a
type of hot exhaust, even in low acceleration and without contravening the bans
imposed by the FIA on the electronics.
Suspension: Untried, at least for the Reds, the rear axle will be very low and very
wide, but most importantly will be a pull-rod rear suspension design, in line with
what most of the other teams have been using since 2011 based on the
revolutionary design introduced by Red Bull in 2009. Based on the McLaren,
however, the driving position, with the driver more reclined and seated lower; a
choice that was experimented with by the Ferrari drivers on the 150' Italia since the
Turkish GP. The new Ferrari should therefore appear slimmer and smaller at the
sides and at the rear axle. Finally, let’s not forget that the responsibility for the new
project, Pat Fry, had the same role at McLaren in 2009, thus it is inevitable that there
will be some similarities with the MP4 single-seater.
Word from TruZoneF1 & Jose Louis is that the new floor Byrne recently came up with has been preliminary tested in CFD and the results have been in line with what Rory thought they would be. It seems that the new floor seems to seal the air below to the diffuser and seems quite effective. Next is more analyzing the data, further CFD testing to make sure other parts aren't being affected negatively then the tunnel.
Also has Pat Fry has mentioned publicly they've had problems since changing how the TD does things & outside manufacturers haven't been able to keep up. Word is Montezemolo made a call and made an ultimatum; 5 days to have the new parts there or Ferrari would pull out as well as all Fiat & Chrysler needs. The parts are in Maranello already with one of the vendors using a private plane. Can't wait for the first test!!
ESPImperium
ESPImperium
64
Project 663 will be driven by Massa on Test day 1.
timbo
timbo
111
ESPImperium wrote:Project 663 will be driven by Massa on Test day 1.
Will they do shakedown in Fiorano before heading to Jerez?
Tyler
Tyler
allstaruk08 wrote:theres one of these every year for ferrari lol
Just look at that nose!! it looks terrible - 2012 cars have the potential to look very ugly!
I hope that doesn't turn out to be the case.
aleks_ader
90
LOL that is just ilustration of rule changes! LOL
maued
maued
I'm the user MrRockhopper that you see in the twits of the Spanish people as #TruzoneF1 and #joseluisf1. I want to give you more information: The floor in CFD simulations gives 0,4 seconds. But not is a exhaustive test. And another information: Ferrari has filed Steve Clark to be the new engineers responsible of the track.
ESPImperium
ESPImperium
64
Probably do the usual 33 laps of Fiorano before they take 663 Chassis No 292 or 293 to Jerez. Its Traditional for the afternoon of the Launch day for Ferrari to shakedown, and will probably shakedown with Alonso at the wheel for Massa to do the first test day.
raymondu999
Interesting. The old head of Bridgestone's F1 venture; Hirohide Hamashima; has joined Ferrari.
失败者找理由,成功者找方法
Holm86
247
Launch is third of febuary in Maranello. If it hasnt been mentioned.
CHT
CHT
-6
Ferrari just announce the signing former bridgestone director. 2012 Ferrari better be quick, or else it will be a major PR disaster for the team.
http://www.autosport.com/news/report.php/id/96940
scuderiafan
Hiring Hamashima is great for Ferrari. If they can keep their tires fresher for longer out on track, they will certainly be faster next year.
"You're so angry that you throw your gloves down, and the worst part is; you have to pick them up again." - Steve Matchett
Patiently waiting...
raymondu999
scuderiafan wrote:Hiring Hamashima is great for Ferrari. If they can keep their tires fresher for longer out on track, they will certainly be faster next year.
Their problem in 2011 has never been keeping tires fresh; it's burning tires! :lol:
Having said that; when coming to a circuit with heavy traction demands; it seems that that problem didn't plague them last year, and sometimes in that scenario ate the tires up quicker - see Singapore for example.
失败者找理由,成功者找方法
