Pup wrote:That's my assumption, but then there are quite a few permanent retaining walls already being built. At least, I assume that they're permanent - in the photos, they look like stacked stone, which seems temporary, but then again, it's stacked finished limestone, which I assume isn't cheap even in Texas. I know we pay a lot here for Texas limestone, but maybe it's cheap enough there to use as riprap?
The part I emboldened is something I think we need to determine. If it is a permanent retaining wall, depending on its load, it has to have a concrete footing and proper rebar placement. I'm not sure about Texas but that looks to me that it might require a "keyed" footing depending on the height. Some of that wall looks like it is over 5.5ft high That would require a keyed footing(in California). I've attached a pdf, it is only 4 pages and the diagrams on the last 2 pages have good examples of keyed footings. Its purpose is to keep the wall and footing from moving/sliding if the bottom of the footing is flat.
Hairy were you there when they started building the wall? Maybe you can shed some light in this matter?
http://www.sdcounty.ca.gov/dplu/docs/DPLU084.pdf
munudeges wrote: he'd be absolutely aghast at that stack of s***. Uneven, not cut properly, not filled in properly
Your father may have also known that "Only children and fools are judges of half finished work".
There is also this:
http://www.theaustingrandprix.com/news/ ... ricas.html
I'm not sure who is doing the analysis but it refers to retaining walls 8 to 15 ft tall.
Example of retaining wall; source: Building Construction Illustrated//Retaining Walls
From photos released as early as October 26th, we can see evidence of retaining wall construction around the track. With a high degree of elevation variability, the track design calls for a substantial amount of retaining walls to assist in the retention of earth and allow for drastic shifts in elevation. Keep in mind that soil can only be modified to 1:4 rate (1 foot rise per 4 feet length) and anything beyond this requires a retaining wall to hold it back.
In these photos from COTA, we can see retaining walls from approximately 8ft to 15ft tall, all constructed with site-cast concrete. Site-casting is the term for concrete structures are constructed on site with wooden or metal forms to shape the concrete. From the illustration of an example retaining wall, we can see that there are two pieces, the footing at the bottom, and a wall which sits on top. The footings are poured first, and then the wall is poured, both with lots of steel reinforcement to increase strength. From the photos of the retaining walls, we can see evidence of these different components as workers construct form-work and tie steel reinforcement to prepare for the addition of concrete.
While not the most glamorous of features at COTA, retaining walls are an essential part of the design of the facility. They provide a tool for designers to add elevation shifts and minimize the cost of reshaping the land, and therefore an integral part of the 133ft of elevation change at Circuit of The Americas.
