Bodywork cooling -a patent
shelly
shelly
136
Looking for heat management and related stuff, besides graphite foam (and its disadvantages, like dust intolerance), I also found this interesting patent:
http://www.faqs.org/patents/app/20110198070
about "MOTOR-VEHICLE WITH AN AUXILIARY COOLING SYSTEM INCLUDING ONE OR MORE RADIATORS CONSTITUTED BY VEHICLE BODY COMPONENTS"
it comes from FIAT. Will we maybe see soon a racing application of it?
twitter: @armchair_aero
Richard
Richard
Re: Bodywork cooling -a patent
That'll be interesting to the FIAT works team.
To be pragmatic, it might have some benefit in a road car with low heat loading and high surface area. Those circumstance don’t really apply to F1 with high thermal loading in a small surface area?
Raptor22
Raptor22
26
it would explain whyFerrari is rumoured to have two large wings aheadof the radiator intakes, covering the crash structure
shelly
shelly
136
richard_leeds wrote:That'll be interesting to the FIAT works team.
The patent is about an auxiliary system, so one could argue that every helping hand counts, even if just dissipates a fraction of the heat.
If I had to imagine a F1 application, it would be on the step plane, in conjunction with slightly smaller conventional radiators.
The step plane is flat, so it's easier to manufacture; plus you have almost 3m2 of surface, low height meaning no cg compromise, plus air flows fast under the floor, plus if you heat that air you get rayleigh effect on the flow.
Seems too good to be true (and probably is)
aleks_ader
90
That sort i just think if Ferrari Mount exhaust pipes more flaterned toward the bottom flor and disipated heat flow throw flor? Samo principe like in your hood cooling patend?
The patent could also be used by a race team to cool the hybrid system rather than, as currently, using a traditional cored radiator. Certainly it possibly gets around the issue of having a lump of metal and water high up on the car as in the McLaren last year...
kilcoo316
kilcoo316
21
Supermarine tried a similar cooling system with the Type 224 - the first design in a path that eventually led to the Spitfire.
The 224 was a complete utter failure.
I guess the thing is not to try to use the system to cool a 600bhp V12 engine. But a smaller heat source such as the MGU in a KERS system might be more successfully cooled this way...
shelly
shelly
136
If it is auxiliary, you can cool part of the engine (105? 20%?) and gain from the consequnet reduction in radiators' size, both directly (less drag) and indirectly (better sidepod shape)
True.
MIKEY_!
kilcoo316 wrote:Supermarine tried a similar cooling system with the Type 224 - the first design in a path that eventually led to the Spitfire.
Think that had more to do with it being rubbish in almost every other way.
And it used evaporative cooling.
xpensive
xpensive
214
Do you really have to be an old geezer to remember the "surface cooled" Brabham BT46?
http://www.google.se/search?q=brabham+b ... 00&bih=799
It was just a clever decoy however, to hide what Murray was really working on, the fan-cooled and ground-effect BT46B.
shelly
shelly
136
I hope we will se something like that this year, but with real functionality,not just smoke and mirrors like in the 70s.
