Pierce89 wrote:Ringo, was pullrod automatically better on the 75% of cars ferrari beat?is t worse now that ferrari use it? The reason peopl trust ferrari over you is because they've won more world championships than you
By the way I don't think anyone should be trusting team pedigree or journalists, or me. Best to use your judgement or the judgement of the majority of teams after a couple recent years based on evidence, performance and trends.
Based on the trends it was a no brainer that Ferrari were slow to react in 2011. They simply were too conservative. The push rod was not the best choice for them.
If we put aside their pedigree, it becomes easier to see they were behind.
Now that Ferrari is switching their suspension, what does that say about their choice in 2011?
The engines are the same, someone said earlier ferrari couldn't fit a pull rod because their packaging etc. etc. When we had a ferrari powered car, the STR using pullrod with the same engine. What has changed?
Now Ferrari themselves are exploiting the benefits, even splitting their radiator in 2 parts and placing the smaller part where the old push rod bits used to be.
Difficulty is not the question. An f1 car is designed to make full use of the regulations to extract as much performance as possible.Are we still on about one layout is better than the other because of the layout, not the reason of why it is used?
If only designing a system is so easy....
The comparison between layouts is not so much the layout itself. It's really what the layout permits. A push rod layout does not carry as much benefit as the pull rod.
This thread is over a year old, and it's been a very good discussion; aside from the fact that we didn't really see any advantages of the pushrod stated.
The next question is if pushrods are extinct. Will we see any in the rear on any car this year?
If so, we can look at why they choose it.
