Ferrari F2012
Alexgtt
Alexgtt
Re: Ferrari F2012
OK! Not exhaust slots at all then. Just heat protected mats with black strips holding them on?
Crucial_Xtreme wrote:Hiding diffuser/rear wing. Heat shielding on exhausts. right click>view image
n_anirudh
n_anirudh
Re: Ferrari F2012
Is that just a hinge for the 2nd element of the rear wing?
Re: Ferrari F2012
You're talking about the hinge for the DRS or is there something else I don't see ?
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Ferrari testing different suspension anchors
Launch day
today
230
Re: Ferrari F2012
Tozza Mazza wrote:
imightbewrong wrote:Are Ferrari using some loophole to run in excess of two elements on the edges of the rear wing?
By rules, that's the endplate.
Crafty buggers.
They wont get much from it though, but it's something.
raymondu999
Re: Ferrari F2012
Crucial_Xtreme wrote:today
That looks pushrod to me :?
失败者找理由,成功者找方法
amouzouris
105
Re: Ferrari F2012
i think you are talking about the steering arm..its not a pushrod
dren
226
Re: Ferrari F2012
It looks like the Ferrari is blowing the inside of the side supports to the rear wing. I am guessing they are trying to keep the flow energized in this area so they can generate downforce over the full length of the wing. You can see the several slots all the way up the wing at the edge.
Honda!
Alexgtt
Alexgtt
Re: Ferrari F2012
No, still pullrod. That's the steering arm.
230
Re: Ferrari F2012
dren wrote:It looks like the Ferrari is blowing the inside of the side supports to the rear wing. I am guessing they are trying to keep the flow energized in this area so they can generate downforce over the full length of the wing. You can see the several slots all the way up the wing at the edge.
That's the most energized area on the wing.
With that separator by it, it's not going to change much. It will have more upwash and maybe it will draft some of the flow in the middle of the wing, but it wont be as effective as a full 3 element wing.
If they blow it with exhuast it may be more effective i guess.
230
Re: Ferrari F2012
double post
dren
226
Re: Ferrari F2012
I thought flow stagnated against the friction of the side supports? That's why they have the slits on the top part to bleed it.
Honda!
Mazdaboy
Re: Ferrari F2012
Ooops...
Every race ends when the chequered flag is out!
forty-two
Re: Ferrari F2012
Still a bit of work needed there eh?
Still, that's what testing is for I guess!
The answer to the ultimate question, of life, the Universe and ... Everything?
munudeges
munudeges
-14
Re: Ferrari F2012
I thought Ferrari were using these much vaunted 'exotic' heat-proof materials? At least according to the Twitter feeds I read. :lol:
