It's not the air flowing over the side pod that deflects the exhaust, it's the low pressure generated underneath the exhaust flow by the shape of the channel in the bump. It's also not 90° that they're deflecting it through – more like 20-30°.amouzouris wrote:i actually said before that i think mclaren is trying to seal the diffuser by deflecting the exhaust plume...BUT on second thought i find it hard seeing how air moving from 180-300 kph could deflect the exhaust plume traveling at 600-700 kph at 90 degrees...also..last year the exhaust was far closer to the floor but we didnt see any kind of floor burning because of the use of heat shielding materials...so why wouldnt mclaren use heat shielding materials again which would both keep what they are doing a secret...so what we are seeing on the floor might actually be parts of the tire ripping apart and being thrown on the floor by the wheel turning... since they are probably blowing the brake duct fins and also blowing the edge of the tire ripping it apart...
i also had a look on the sauber solution which is very different i believe as they are trying to keep the plume attached to the bodywork...not deflect it by the airstream..
With the minimum initial angle of the exhaust set at 10 deg up, turning the flow 20 deg is only a net of 10 deg down (yes, yes simple math...). I haven't done a scale drawing, but if that is a scorched floor and not just tire rubber, the exhaust is making a much more significant turn than just 30 deg.beelsebob wrote: It's not the air flowing over the side pod that deflects the exhaust, it's the low pressure generated underneath the exhaust flow by the shape of the channel in the bump. It's also not 90° that they're deflecting it through – more like 20-30°.
I agree...also wouldn't a low pressure below the bulge decrease the efficiency of the floor?volarchico wrote:With the minimum initial angle of the exhaust set at 10 deg up, turning the flow 20 deg is only a net of 10 deg down (yes, yes simple math...). I haven't done a scale drawing, but if that is a scorched floor and not just tire rubber, the exhaust is making a much more significant turn than just 30 deg.beelsebob wrote: It's not the air flowing over the side pod that deflects the exhaust, it's the low pressure generated underneath the exhaust flow by the shape of the channel in the bump. It's also not 90° that they're deflecting it through – more like 20-30°.
You've measured from the back of the bump – the exhaust pipe is at the front of the bump. Remember, that's a launch car.amouzouris wrote:I actually measured the angles...here have a look:
In all honesty, it looks like tire marbles in that pic. I've been mistaken. But why would someone who could see the car up close (Ted Kravitz) with naked eyes would report that the floor has burn marks ? It strikes me as odd. Maybe he's been mistaken in the same way some guys including me have been mistaken.Owen.C93 wrote:
Yeah just marbles by the looks of it. I doubt McLaren could really blow the floor and make it worth while.
Right click view image to zoom in.
As another fellow member pointed out, could that be because of the exhaust flow coming too close to the tyres for comfort ?amouzouris wrote:yup...tire marbles....so now the question is...does the car destroy its tire sidewalls??
Well Sauber just introduced a similar concept and this is their rear tyres.amouzouris wrote:yup...tire marbles....so now the question is...does the car destroy its tire sidewalls??
