I saw something similar to that vane on the RB6, maybe the 7 as well...Crucial_Xtreme wrote:Rear end detail. Amazingly tight package. Isn't the little vane on the floor closest to the track new? right click>view image
I'm sure you are correct. I'll wager this undertray was built just for testing, allowing them to swap different bits in and out to find what works best in a timely manner.Robbobnob wrote:On those two photos there seems to be a section of the floor that is detachable.
Here it is attached
and here it is missing
It seems Red Bull are still investigating "sealing the diffuser" somehow
That is Flo-vis paint, which helps them see where the airflow is going. I don't think it is necessarily heat sensitive, but that is bound to be one of their concerns in that area, for sure.strad wrote:Interesting picture of the heat sensitive paint,,there to see if that exhaust is gonna burn up parts I'd reckon.
Yes thetre is Flo-Vis also,,but the little patch shaped/little squares, are heat sensitive paint.That is Flo-vis paint, which helps them see where the airflow is going.
Der...didn't notice those! And the two blue patches in the middle...strad wrote:Yes there is Flo-Vis also,,but the little patch shaped/little squares, are heat sensitive paint.That is Flo-vis paint, which helps them see where the airflow is going.
Different philosophy, McLaren by mounting the exhaust further back and further from the centre line of the car seem to pointing their exhausts at the floor on the inside of the tyre. You can’t blow this area from where the RB8’s exhausts are positioned.JB2011 wrote:This seems to be a significant distance further back than McLaren's exhaust exit. Why wouldn't McLaren also mount them this far rearward and then add on their extra bit of bodywork?Crucial_Xtreme wrote:RB8 exhaust in action
Nice drawing, and you raise some interesting thoughts about the wishbone's effect on the subsequent path of the exhaust.Robbobnob wrote:im not sure what benefit this would have, but having that upper wishbone next to the exhaust flow has the following benefits.
As the wishbone is not considered bodywork, it can be within the 3degree cone, therefore interact with the stream acting as a sort of turning vane.
the top is just the exhaust as it would naturally expand, the bottom situation is how it would expand with the wishbone in its path.
my guess would be its concentrating the flow onto the middle section of the bean wing, wouldnt be surprised if we see a ultra complicated looking monkey seat at the last test, nor do i think we have seen the final iteration of this exhaust solution
I agree completely. I think the exhaust is mainly aimed at the underside of the lower wing, but Newey is taking advantage of running it under that suspension member as well. And at higher vehicle velocities (such as on straights), the exhaust flow will be blown more straight back, un-attach from the wing, and reduce the drag when downforce isn't needed.Robbobnob wrote:yes i certainly agree that it will have extra downforce across the wishbone, but Newey is the King of multi benefit aero parts so i am almost certain that there is other benefits going on
