ginsu wrote: i don't see how you could make a spherical car. although, it would change direction quite well if you could.
It is not an spherical car, only the wheels. You can keep the car pointed in any direction while the wheels push it sideways. You do not have to rotate the car.
BTW, I have seen, maybe a year ago, a radical car (Peugeot?) that has a giant wheel that goes round the cockpit. It is beautiful, but I have not been able to find it on the web again.
I forgot to mention that a car with zero moment of inertia would have zero resistance to bending. It would be the worst chassis in the world. When you design a bridge (or a chassis, I imagine) the torsional and bending moment resistance depends on the third moment of inertia, wich is the integral of the area, when you "turn" it around an axis perpendicular to the load. No inertia, no resistance.
