Adrian Newby wrote:n smikle wrote:Adrian Newby wrote:PIC
http://www.taringa.net/posts/autos-moto ... l-RB7.html
This gives a good idea of where:
(1) the top intake could enter the chassis above the driver's toes, "cool the driver", and then exit through the cockpit opening, and
(2) the bottom intake could enter the chassis below the driver's heels and be routed to the KERS unit behind the driver's seat (and under the fuel tank).
Yes this is what I was saying to you above. There is also two big sponges that wrap around the driver's legs. So there is a lot of stuff to back the air up inside there.
The only way it can be circumvented (pun intended) is to have two tube that route around all those obstacles in the cock pit.. but there you are talking about a lot of drag.
The area along the top inside of the chassis is above the legs and relatively clear, or could be made so easy enough. The bottom intake was there last year, so they already have that ductwork figured out. Once again, this drag does not matter. They have bigger concerns they are trying to address with this air.
I know what you are saying I am not going against it, but I think you have to give an Idea as to what magnitude of side spill you claim they are trying to avoid, especially since this is above the chassis and very much close to the wheel centre line. And why didn't they just make the step smoother? Like the Caterham that would be just as or even more effective if it was only side-spill they are trying to control.
Because ironically, damming up the Air as Newey does actually causes more side spill.
Very much similar to the top surface of the rear wing and it's end plates. Agree?
Notice that the rear wing has even bigger slots (between top and bottom plane) and you still get massive side spill and vortices causing drag. Just merely because the air is impeded on the wing side and free flowing on free stream side of the end plate. Agree?
And as you know gills are cut in the end-plates to help ease the pressure transisiton resulting is more cleaner flow coming of the rear wing endplates.
So, using this logic, that Is why I believe that Newey would not go down the route of trying to impede air just to turn back then create slot to release it. That would just be creating a problem for the sake of solving it.
It must be something else that he is backing up the air for. (Reportedly driver cooling) But the air damn could be for an f-duct, or flow deflection (like the hollow point bullet).
