Well, the surface of the wheel is rotating at 350 kph, same speed as the car. Drag works inside the wheel as well as outside. Any difference in rotational speed between the tire and the gas inside is expressed as drag. Given the big surface of an F1 tire, the small volume of gas inside and the drag coefficient, I am pretty sure that the gas acquires the rotational speed of the tire really fast. Even while the air is rotating slower than the tire, it produces drag, so it is acting all the time. You could do the math, I am sure, or you could simulate it. Hey! New idea: do the aero design of the interior of the wheel...Tomba wrote:First of all, I don't think the rotational mass reduction is important since we are talking about gases here...
- Another reason for using N is that O is that there is 3 times less leakage. I'm not sure how Helium might do here though
Seriously, I am also pretty sure that the "inside drag" effect is probably worse than to have the air rotating at the same speed of the tire, because drag effects are proportional to the cube of the velocity, while mass effects are proportional to the square of the velocity, so I do not know if some kind of "inner paddles" could help here, or maybe some kind of really light chambers.
The permeation rates of hydrogen, oxygen and nitrogen in rubber on a vacuum (you really can find anything on the Web) are 2.2, 2.0 and 0.53 (all expressed in 10^-8 square cm/sec). This means than on a rubber container, oxygen is 4 times more prone to diffusion than nytrogen and helium is just marginally (10%) harder to contain than oxygen. This is an approximation, as I understand that this is measured with vacuum at the other "side" of the rubber being tested.
No, Tom. It increases its mass in the same amount as the mass of the lighter than air element. You get buoyancy because of Archimedes effect (eureka!), but this is a different thing: it is because you are replacing air with something lighter and the air "around" pushes it with the same force as if this lighter element were air.Tom wrote:If an element lighter than air is added to an object of a certain mass (say 5kgs) surely that mass decreases?
This reminds me of an old "joke": what weights more, a pound of lead or a pound of feathers? A lot of people, instinctively, answers that a pound of lead...
