I have made some measurements based on the front rim diameter and the article from f1 regulation manual (12.4.4 Wheel bead diameter must lie between 328 and 332mm).
I have taken 330mm as default rim diameter to all cars.
right click
![Image](http://i1153.photobucket.com/albums/p517/ovidiulucaci/2012Cars.jpg)
There is a better scale length that I used last year. The regs specify a fixed dimension from front of the front wing to the front axle. It is roughly 1000, so that would give more accurate scaling. You need to use the leading edge of the nearside endplate to the centre of the wheel as they are roughly in the same plane.ovidiulucaci wrote:2012 Cars
awesome! good job mate!ovidiulucaci wrote:2012 Cars
The Ferrari seems to be the shortest on the 2012 grid and Mercedes AMG to have the lowest sidepods.ovidiulucaci wrote:I have made some measurements comparing carsviewtopic.php?f=12&t=11818&p=312719#p312719
no they are wrong, outer wheel lip diameter is 358mmbhallg2k wrote:Nope. They're just about right. Close enough, anyway.
