Yep...BIG difference.Looks more like inadvertent heating of a portion of the tire rather than really trying to heat up the tread.
Pup wrote:Way below.beelsebob wrote:The article below?
And here's the confirmation...
http://www.autosport.com/news/report.php/id/97662
So they say 'manufacturer' singular. Perhaps Merc wasn't involved at all?
The idea behind the KERS/HERS is to safe fuel. If a blow diffuser uses more fuel for working correctly (blowing when braking), it is against all this eco-friendly-green-flowerpower F1 the FIA wants to create.mx_tifoso wrote:Why can't they see the blow diffusers as a sort of HERS? The exhaust is being reused to provide downforce, instead of power. Win win ffs.
Please restate, this seems a normal condition, nothing to do with 'off throttle' blowing.hardingfv32 wrote:[quote="n smikle"I think hot blowing may still be achieved at any throttle position but it would ONLY work at full strength in that Narrow window when the throttle is wide open by the driver's foot - during acceleration out of the corner
IF it 'sounds' like last year then it is 'hot'. Is that an invalid way to read the sentence. Now you could argue some idiots were cold blowing last rear, but they were not winning races with that strategy. And I doubt anyone was making note of their exhaust sound other than to note how weak it was.strad wrote: have said they sound like last year..still blowing off throttle
What then are you talking about? Are you saying that the exhaust can't be aimed at anything? You must be joking?n smikle wrote:Off throttle blowing is banned. You were not talking about "Hot Blowing?" Hot blowing can be independent of off throttle blowing.
hardingfv32 wrote:Now you could argue some idiots were cold blowing last rear, but they were not winning races with that strategy.
Brian
I think that would turn into speculation (depending whether the engineers at the test can even hear it), and how discernable your ear is. The YouTube’s we get are not always that audibly sensitive.It will be interesting to see if there is any major change in tomorrow's practice. I guess if the cars sound different, we'll know who was using it and who wasn't.
And if someone is using it, they may not want to reprogram on their own until next week’s practice starts in case it may skew this week’s data. Or they may desparately want to know today but they may only change it for a small part of their program.A software update for the standard ECU will be issued later in March to ensure this route of development cannot be further investigated
I am talking about the difference in engine operation between hot blowing and computer controlled off throttle blowing.hardingfv32 wrote:What then are you talking about? Are you saying that the exhaust can't be aimed at anything? You must be joking?n smikle wrote:Off throttle blowing is banned. You were not talking about "Hot Blowing?" Hot blowing can be independent of off throttle blowing.
Brian
He's definitely not saying that in any way. He's saying that hot blowing and off throttle blowing are 2 separate concepts, and I agree. I was under the impression that most teams were hot blowing off throttle last year ie. a combination of the 2. Off throttle blowing was simply opening the throttle while the driver was off the pedal, hot blowing was retarding the ignition to dump unburnt fuel into the exhaust which would then combust and create a hot burst of exhaust gas. They're not one and the same, and can happen independently of each other. So the new regs on engine maps this year are meant to cut out hot blowing, the rules linking the throttle to pedal position are meant to cut out off throttle blowing.hardingfv32 wrote:What then are you talking about? Are you saying that the exhaust can't be aimed at anything? You must be joking?n smikle wrote:Off throttle blowing is banned. You were not talking about "Hot Blowing?" Hot blowing can be independent of off throttle blowing.
Brian
Wouldn't everyone that was off throttle blowing technically have used a small amount of cold blowing? Just because teams were hot blowing doesn't mean they were 100% constantly hot blowing when off the throttle, i'm sure there will have been an element of cold blowing in there as well.Gridlock wrote:hardingfv32 wrote:Now you could argue some idiots were cold blowing last rear, but they were not winning races with that strategy.
Brian
Weren't Renault using cold blowing last year Brian? How did that work out for Red Bull?
Are you implying that McLaren reported it? It's widely reported that the Renault and Mercedes engined teams were already in on this. And McLaren are a Mercedes engined team.Mr Alcatraz wrote:As we know the manufacturer of the standard ECU is McLaren Electronic Systems. As to who, if anyone is exploiting it here-to-for is unknown. The identity of the team that has brought it to the attention of the FIA is probably one that discovered this loophole independently while investigating it for its own possible benefit from it.
Perhaps. But remember that the teams are allowed to use a different map at the starts to the rest of the race. This map has to run for the entire first lap (to stop people having TC for the first 100m).hardingfv32 wrote:Another half baked idea.
Brian
