Launch Analysis: Red Bull RB8
http://scarbsf1.wordpress.com/2012/02/2 ... -bull-rb8/
It has reduced the size of the actuator, also. Perhaps the importance of this area has increased now that diffuser blowing is banned.shelly wrote:So this arrangement with pillar and conventional looking endplates is just a first step. I excpect new endplates to come out in next test or in melbourne
I look forward to your explanation.bhallg2k wrote:Interesting. You don't often see Red Bull copying a Ferrari concept (DRS/wing pillar).
No. Just no.RB7ate9 wrote:I agree, I think the thinness of the letterbox betrays the fact that the volume flow rate through there is much higher and more direct than placing a hole in the front of the nose that will lose more energy by the time it gets to the cockpit.
More accurately, why was this not done in the last 10-20 years on any formula car?RB7ate9 wrote:Also, an added benefit is to add energized flow over the sidepods. Seems like a simple enough modification, I wonder why this wasn't as prevalent on 2011 cars?
If it was Newey's should it not have a gurney on it?RB7ate9 wrote:Based on the pointed elliptical shape of the exhaust, this must be Newey's latest innovation to be copied by every other teamtjaeger wrote:Any idea what it is used for? Purpose?Crucial_Xtreme wrote:Hmmm.... I do not remember seeing this before.
[img]http://img850.imageshack.us/img850/4585/338v.png[img]
Could that be the exist of air collected at the slot in the hump of the front wing? Would this add any value, advantage?
One explanation could be that having that disturbance wouldn't be offset with aero benefits. Perhaps even with any high-pressure build-up, the exit doesn't have enough flow to either create a smoother boundary layer, add energized air to the rear flow, or overcome the turbulence from such a sharp cut. The presence of assorted exits on the sidepods next to the cockpit during race weekends suggest a benefit, but whether or not it extends beyond simply being more effective at cooling the driver during hot days is questionable, as, at first, I had thought that this was a new development until someone pointed out that these have been on cars for years.hardingfv32 wrote:More accurately, why was this not done in the last 10-20 years on any formula car?RB7ate9 wrote:Also, an added benefit is to add energized flow over the sidepods. Seems like a simple enough modification, I wonder why this wasn't as prevalent on 2011 cars?
I does not work!
Brian
The general consensus thus far has been that the stepped noses do not inflict much of a drag penalty, because of the way air flows over the top of the nose. This is borne out when you make a comparison between RB7's nose inlet and RB8's "letterbox." The "letterbox" is much, much larger, because the airflow into it is nowhere near as direct or abundant.RB7ate9 wrote:I look forward to your explanation.bhallg2k wrote:No. Just no.RB7ate9 wrote:I agree, I think the thinness of the letterbox betrays the fact that the volume flow rate through there is much higher and more direct than placing a hole in the front of the nose that will lose more energy by the time it gets to the cockpit.
Can you further explain why this is considered a costly solution?n smikle wrote:The rack that holds the sensors look like its CNC machined from one slab of billet aluminum..$$$$ no matter why they left FOTA.
That actual hole in the letterbox doesn't appear to be that big. I recall it is limited to the same area as the nose inlet, or the ducted inlet Schumacher use last year.bhallg2k wrote: The "letterbox" is much, much larger, because the airflow into it is nowhere near as direct or abundant.
I can't wait to get a picture of the RB8 bulkhead with the nose off! We will get one. Might not be until Monza, but we'll get one.richard_leeds wrote:That actual hole in the letterbox doesn't appear to be that big. I recall it is limited to the same area as the nose inlet, or the ducted inlet Schumacher use last year.bhallg2k wrote: The "letterbox" is much, much larger, because the airflow into it is nowhere near as direct or abundant.
I agree the surrounding ramp does seem to be shaped like a dam which would infer that you can have a relatively large disruption at that point without too much penalty.
You'll get one at FP1 on 15 March, they have to have open garage doors are race weekends. We sometimes get some good pics the day before when they are setting up.Crucial_Xtreme wrote:I can't wait to get a picture of the RB8 bulkhead with the nose off! We will get one. Might not be until Monza, but we'll get one.
