The blue arrow air should be directed into this red hole
No it wouldn't... because the flow isn't going to the diffuser.amouzouris wrote:i just had a thought...could that hole hide inside a cooling exit from the sidepods??? that would increase the volume of flow to the diffuser...
The starter hole ???Crucial_Xtreme wrote:That starter hole is huge!
right click>view image
Agreed – having seen the positioning of the starter hole, the blue line should indeed be heading for there.Crucial_Xtreme wrote:Everything in this picture is correct except it needs the blue arrow to go into the hole that leads to starter. Although I would think some goes down & some air stays up no?
dk, just asking.. with all that blowing nonsense going around...beelsebob wrote:Why would it not be? Which rule do you think it breaks?Goran2812 wrote:is that hole even legal?
umm...excuse me?? here is the other end of the hole...it looks like its going to the diffuser to me...beelsebob wrote:No it wouldn't... because the flow isn't going to the diffuser.amouzouris wrote:i just had a thought...could that hole hide inside a cooling exit from the sidepods??? that would increase the volume of flow to the diffuser...
Uhh, you can't see the underside of the diffuser in that picture... what on earth are you talking about?amouzouris wrote:umm...excuse me?? here is the other end of the hole...it looks like its going to the diffuser to me...beelsebob wrote:No it wouldn't... because the flow isn't going to the diffuser.amouzouris wrote:i just had a thought...could that hole hide inside a cooling exit from the sidepods??? that would increase the volume of flow to the diffuser...
I was commenting on the post above when I replied.J-L wrote:The starter hole ???Crucial_Xtreme wrote:That starter hole is huge!
Where you see it ??
i think we are misunderstanding each other!!:P im talking about the hole on the back side of the sidepods...its getting air from the hole in the side... and i was wondering if that could also be a cooling exit for the sidepods....meaning air exiting from that hole could be clean air from the side and air from inside the sidepods...thus increasing the volume of flow at the top of the diffuserbeelsebob wrote:Uhh, you can't see the underside of the diffuser in that picture... what on earth are you talking about?amouzouris wrote:umm...excuse me?? here is the other end of the hole...it looks like its going to the diffuser to me...beelsebob wrote: No it wouldn't... because the flow isn't going to the diffuser.
It could be – but I doubt it, their cannon exit above the beam wing seems more than sufficient.amouzouris wrote:i think we are misunderstanding each other!!:P im talking about the hole on the back side of the sidepods...its getting air from the hole in the side... and i was wondering if that could also be a cooling exit for the sidepods....meaning air exiting from that hole could be clean air from the side and air from inside the sidepods...thus increasing the volume of flow at the top of the diffuser
Is my screen that bad? Don't think so.beelsebob wrote:Optical illusion – that slot's open.Timstr wrote:Slot closed here:
