Red Bull RB8 Renault
beelsebob
beelsebob
85
Re: Red Bull RB8 Renault
siskue2005 wrote:Is it really legal to channel the exhaust like rbr are doing now?
The rule clearly states that you can't channel the exhaust #-o
Which rule, where?
beelsebob
beelsebob
85
AnthonyG wrote:
Crucial_Xtreme wrote:That starter hole is huge!
right click>view image
http://www.formula1.com/wi/sutton/2011/dms1203ma36.jpg
Why is the slot on top of the sidepod open on the right, but closed on the left?
(first time poster so sorry if this allready was asked somewhere)
Sorry, I don't see what slot you're referring to.
Mchamilton
Mchamilton
Which rule, where?
red bull arent 'channeling' the exhaust anywhere from what i can see, the tunnel under the side pod bridge is legal as the bodywork radius rule only starts 50mm above the floor
siskue2005
70
Which rule, where?
I can't find the rule or section
But the FIA were clear that exhaust flow cannot be channeled for aero purposes
AnthonyG
38
I took the wrong picture, this one
http://www.formula1.com/wi/sutton/2011/dms1203ma31.jpg
(top slots on the leading edge)
beelsebob
beelsebob
85
AnthonyG wrote:I took the wrong picture, this one
Good spot! Also, they have a tiny little vein on the right, but not the left.
I'd hereby like to do something important for the board:
=D> :wtf: =D> ASYMMETRY ALERT | ASYMMETRY ALERT | ASYMMETRY ALERT =D> :wtf: =D>
:P
Lurk
:P
:mrgreen:
It could be to compare 2 cooling solutions, or different cooling requirement from each side. One side could have 1 radiator for engine coolant and the other side 1 for engine coolant and 1 for something else. Don't know if some are still using this solution or if they all switched to "offset" position for the 3rd radiator, above the gearbox for example. But it wasn't uncommon some years ago.
Hail22
144
If thats the case, looks like the concorde agreement will have some very angry teams, media and sponsors forcing bernie and the FIA to implace the RRA in law/ruling.
Gilles Villeneuve
bot6
bot6
One thing is for sure looking at this car. RB spent a lot more resources and a lot more money designing and building this car than the other teams.
RRA my rear end.
CHT
CHT
-6
anybody manage to find picture of the rear diffuser?
AnthonyG
38
Wondering: are there any FLIR shots of this car (and others)?
I think a FLIR camera would point out instantly how the exhaust flows. (and some other airflows)
Dragonfly
Dragonfly
The exhaust placement and ducting may be similar to Sauber's but below is a totally different solution for channeling the air flow.
Image is jaggy because I tried to filter it to make the rear sidepod part shapes more visible.
Spa 2012
Byronrhys
AnthonyG wrote:Wondering: are there any FLIR shots of this car (and others)?
Doubt we'll be getting any thermal shots in testing, for sure we'll get some when the season starts.. wonder if the teams use these to help them analyse exhaust flow and if it would be useful.
radosav
radosav
the fact that one under-sidepod slot is closed and other open and leading air to diffusor tells me that red bull doesn't know much about effect of this kind of exhaust flow. they are comparing one open side with other closed and trying to find some gains. this exhaust may be good at the end but it shows that their first version was mistake and when they saw what other teams made with exhaust they had to make it from the begining. that is why they protested ferrari and mclaren exhaust systems at first test. they didn't hide it from the begining and leaving it as surprise for the last test.
bot6
bot6
They're both open.
