FakeAlonso wrote:Interesting article from Sky on Ferrari.
"Alonso's trip into the turn one gravel during qualifying came as they put their outer wheels on the grass under braking. Whilst this would appear to be a fairly fundamental sort of error for drivers at this level, it points to a specific trait of the car - namely its instability under braking, and this is almost certainly a corollary of an unfortunate combination of lack of low-speed downforce with the geometry of the car's pull rod front suspension.
Being normally a public road, the Albert Park track has plenty of bumps and one of the traits of a pull-rod suspension is that it's not great over bumps. To minimise its tendency to force the tyre to pull sharply sideways when encountering a bump during cornering load, it needs to be set up with negative camber (wheels pointing outwards at the bottom) so that the cornering pulls the wheel upright. That cures the pull-rod geometry's sensitivity to bumps but introduces a different problem - instability under braking because when travelling in a straight line the tyre does not have its full tread surface in contact with the track.
The exhaust On the Ferrari it is much further back - forming a blockage to the airflow at a crucially sensitive place, where the lower body tapers in.
Such a blockage would be expected to increase drag and give slow straightline speeds and also to prevent the airflow giving much of a blown effect to the diffuser, tallying with the F2012's traits. A lack of low speed rear end downforce would also hurt traction.
Either you didn't quote Sky correctly or Sky has no clue about driving or setup on a race car, everything said in this statement could be questioned as false by someone who sets up cars or drives one....first paragraph anyways...
"Driving a car as fast as possible (in a race) is all about maintaining the highest possible acceleration level in the appropriate direction." Peter Wright,Techical Director, Team Lotus
