Just made some "things" which prolong the airflow from the splitter a bit further up to the sidepods. Forgot it's name, does anybody know?
Oh, yh, I will definately change that, my badjordangp wrote:Well the fin thats flowing inwards, in the middle, where the other 2 are flowing outwards. Your aim really is to direct airflow around the tyre, amongst other things.
I think the wheels are in the right place, however the front wing is not wide enough, I can tell it doesn't fit into the dimensions anyway.N12ck wrote:I can tell you your car is illegal straight away, look at the size of the front wing, 1800mm (no part of the car can be outside this) and your wheels are miles further out
I knew something was wrong with itjordangp wrote:I think the wheels are in the right place, however the front wing is not wide enough, I can tell it doesn't fit into the dimensions anyway.N12ck wrote:I can tell you your car is illegal straight away, look at the size of the front wing, 1800mm (no part of the car can be outside this) and your wheels are miles further out
I knew it!jordangp wrote:That front wing definitely isn't legal, because straight after the central section, you have that triangle area in plan view, and yours can't possibly fit into that.
