N12ck wrote:the homologation rules have changed now, so more than 1 tub is allowed
can you give us a quote of what has changed when?
The RRA is a secret but legally binding agreement between the teams. We have a dedicated thread dealing with all the speculation and with quotes.
viewtopic.php?f=1&t=7695&hilit=about+th ... estriction
There are published quotes by Adam Parr about the nature of the agreement that you can read there. For instance compare:
http://www.telegraph.co.uk/sport/motors ... mentw.html
for a quote before signing and
http://www.motorsport.com/f1/news/teams ... -document/
after signing has occurred.
Calling it a gentleman's agreement is inaccurate because it is not of a hand shake nature. Your sources simply are in error there. This is only natural for most internet based publications. They copy stuff they have read elsewhere. I suggest we restrict the debate to quotes by reliable figures like team principals.
Being secret doesn't obviously help when clauses of the agreement are under discussion. The above article also confirms that the tub is restricted although it is a bit unclear what the restrictions are due to grammatical inaccuracies. I have always thought that re designing the tub is prohibited because I do not know a single case of a B-car being introduced since the RRA came into effect. Prior to 2010 it was the general practise of top teams to have a new tub design in summer. Now they simply don't do it any more. If this isn't directly prohibited by the RRA - which we cannot know due to the secrecy - then it is obviously prohibitively expensive in terms of resources and money.
For the purpose of this thread it is not relevant why a new tub is not feasible. Mercedes have an advantage that other teams can only recover with much difficulty. It is better than an exhaust solution which can be relatively easily copied (like the benchmark McLaren design).
bhallg2k wrote:Regarding the front-wing F-duct, I don't necessarily think it would be that hard to copy. I think it's fed from the scoop on top of the chassis and that the pipes from the rear wing only serve to activate the system.
I fail to see the logic in your point. If the main air stream comes from the roll hoop - as you say - it still has to be piped through the cockpit to the front wing. And that necessitates a design feature like a hollow floor or wall.
