BMW new front Wings?
Sawtooth-spike
Check this out guys,
This has to be one of the oddest things i have seen this season
Maybe it help control are car wile its fliping the in air?
i guess they are to help with air flow, like the Horns on a mclaren.
I believe in the chain of command, Its the chain I use to beat you till you do what i want!!!
zac510
zac510
22
holy moly..
Sure they haven't been attaching cameras to that for video/marketing shoots?
Monstrobolaxa
Monstrobolaxa
zac510 wrote:holy moly..
I'd suspect not!
To me it's quite simple...the downwash created but those wings depending on the way it is rotating can be used to bring somekind of benefit! The question is what benefit? Aibox?
JimmyK
JimmyK
EDIT: Ah, scrap all that.
Go to the ITV-F1 Site and click the link on the right that says 'Bizarre BMW Wings'
scarbs
scarbs
393
or may be provide some sort of yaw resisitance, like the taller spine on their engine cover
walter
walter
I wonder... perhaps these are nothing but covers some new torsion bars... Think back to ferrari's rear suspension introduced in spain. What makes me think of this is the attachment point of these wings, exactly over the front suspension. Secondly I am surprised that they are attached to the nose cone rather than the monocoque, suggesting again that there is something underneath those wings that will need to be readily accessed.
I dont believe for one bit that if they are for air management for the airbox, if they were, there would be no need for a wing profile right at the attachment point, they would use a spacer such as what holds up the side mirrors.
I want to see BMW's suspension without the nose cone, I believe we will know then.
i70q7m7ghw
i70q7m7ghw
49
WTF, covers for torsion bars? Bit extreme aren't they? I dont get it? How can they be covers? They are clearly an aerodynamic device. They are probably mounted to the nose so they can simply swap over to a nose without them for comparison??
mep
29
They have a wing profile.
So they can create a force (but they must not).
There are two of those wings so the forces have a counter effect in a straight line.
But in a bend due to a special wing profile and a diagonal
angle of attack one profile produces more force than the other.
This force points to the inside of the bend and helps cornering.
Other than the force the front wing produces is this wing producing
the centripedal-force directly and not over the tires.
So you can use harder tires
and have although good cornering ability. :lol: 8)
(This is my theory)
m3_lover
I thought those stalks were for a video camera, but I guess they are legit
http://www.itv-f1.com/News_Article.aspx?PO_ID=36553
Simon: Nils? You can close in now. Nils?
John McClane: [on the guard's phone] Attention! Attention! Nils is dead! I repeat, Nils is dead, ----head. So's his pal, and those four guys from the East German All-Stars, your boys at the bank? They're gonna be a little late.
Simon: [on the phone] John... in the back of the truck you're driving, there's $13 billon dollars worth in gold bullion. I wonder would a deal be out of the question?
John McClane: [on the phone] Yeah, I got a deal for you. Come out from that rock you're hiding under, and I'll drive this truck up your ass.
NickT
Figured it out 8)
They are BMW's anti barrel roll fins to allow the drivers to become airbourn yet always land right way up :shock: Aparently the development project was called CATS because it doesn't matter how a cat is dropped it always lands on its feet :wink:
NickT
bhall
bhall
244
I think they're a distraction. Something else is probably slightly, but measurably, different on the car and BMW doesn't want to give it away.
i70q7m7ghw
i70q7m7ghw
49
Take a look at the car today, they aren't a distraction....
Monstrobolaxa
Monstrobolaxa
If they were a distraction they wouldn't only use them for 1 or 2 laps at the start of the day! It wouldn't be worth the work for just a few laps.
johny
no no distraction at all, also mclaren horns
RH1300S
RH1300S
The FIA should ban that kind of stuff...it just looks rubbish. After all car racing is (hopefully) about the fans and why should we have to look at horrid cars.
