alogoc wrote:bhallg2k wrote:You're right. I forgot about that. There's a theory that the
front wing end plates are producing an errant vortex that's contributing to the car's instability. So, of course, if that's the case, I expect the team to attempt to fix it ASAP. However, that could be yet another side-effect of the car being run at a lower-than-intended rake. The resultant change in the front wing's AoA could be the source of the errant vortex.
I always wonder how come they expect the same FW that they had on last year car to work on this year's one when everything that is behind those wings is totaly different!?
Jeez, perhaps because everything is designed to work together!?
The circular discussions on here are getting more and more far fetched. Ferrari haven't just forgotten to update their front wing or accidentally stuck last years wing on the car. They're not just hoping it all works or guessing at the aerodynamics using their eyeballs like everyone on this board.
Many of the same people kindly informing us about all the visible problems Ferrari have were the ones declaring the season over for the other teams when they saw the B spec Red Bull, forum members and journalists alike. The same eyeball CFD, having thought the new Red Bull was going to dominate, is now picking out all kinds of definitive flaws.
Truth is that these are incredibly complex machines, especially aerodynamically, with many many subtle interactions that the teams spend tens and tens of millions of pounds each year studying and refining. There are no glaring errors with any of the cars that any fool could spot. We're talking about subtle interactions failing to play out with 100% accuracy, and dynamics causing maybe a one to two percent difference in lap time. Sure there are differing theories and compromises used by each of the teams, but the end result is relatively subtle and not a night and day difference.
Ferrari, or any other team, cannot simply rush through a change in philosophy. They need to craft and polish the whole solution otherwise an upgrade that may theoretically bring a 2% improvement in lap time may be unrefined enough to actually give a 1% decrease in performance. The margins on these cars really are that tight.
