From the FIA Decision:WhiteBlue wrote:The purpose of steering input is to drive the car around the corner. If you piggy back another function onto the steering system you would open up the dedication of the steering signal to the activation of an aerodynamic device. I do not see the same functionality and dedication in the two systems and I am afraid the FiA would also object.
"(i) Article 3.15 does not apply because it does not directly use driver movement, as a means of altering the aerodynamic characteristics of the car. The alteration is indirectly (and not directly) consequential to the movement of the driver adjustable bodywork ("DRS")"
This statement clear indicates that the driver's body movements must be used as a means to alter the aerodynamic characteristics of the car to be fail 3.15. The steering columns movement is no different than the movement of the RW flap. Both are the indirectly cause by the driver.
Brian
