Nando wrote:raymondu999 wrote:Nando - Coanda isn't about any downwash or housing directing any flow anywhere. It's about this effect: (Guest starring Pup's torch and martini shaker)
Pup wrote:
If you're still unconvinced, fine by me. I'll be off.
Is that your image? If yes. Take a picture when holding the flame horizontal to the top part of the mixer you have and see if the effect is the same.
Or as extreme.
Right now you are blowing the "exhaust gases" directly on to a surface.
I´d like to see a picture where the exhaust gases are horizontal with the highest points of the circle.
I also disagree with the pics posted so far in terms of their relation to what is happening with the cars. I disagree with the blue flame much more than then the yellow.
The exhausts on the cars face up and
away from the lower surfaces of the tunnel by a minimum of three degrees as we already discussed.
Regarding your proposed experiment, we would at most see a bit of bending, but the majority of the flame would just go up in the air (assuming the relevant angles proposed by the regs are followed during the experiment). Unless we introduced the downwash effect similar to the air over the side pods in motion that would then push the flames down onto the cylinders for better effect.
Not only that, but by the time they've made their way out of the tunnel in the cars, the sharp edges of the sides of the tunnel would basically kill off almost any relevant further coanda effect that would pull the fumes inwards, if we are still talking about button being stationary in the pits.
Come to think of it, what if the goal is to have the exhaust gases getting pushed down by side pod flow during fast sections to stop the tyres losing heat, but upwards and away from the tyres when the car is in slower sections, so as to not overheat the tyres while already under heat generating load/friction due to less downforce creating more "slip"?
