Falcon wrote:... Seems like what you’re really pushing for is mandated performance limits rather than physical vehicle limits... After the race we can download the FIA’s black boxes and find out who really won.
Downforce is now mandated through "performance", as you baptize it (hey, I like that distinction, well named, thanks).
For the first time in history, I think, FIA gives you a number: 12500 N. It does not specify body width, diffuser height, materials, wing flexing or whatever, as you point out. It effectively takes out of competition the development of MORE downforce and focuses teams on drag improvement.
You make me think that under present day "methodical approach of scientific thinking" to racing, it has been impossible to limit
all things through dimensions and weights: people find a way around that.
Champcar pop-off valves are a good example: you effectively limit the intake pressure to a number, instead of specifying physically the turbocharger.
Also, your distinction makes me ponder if this "performance limitation" happens when "rule developers" have been circumvented many times. They finally react by limiting "the darn thing" to a fixed value, instead of having an endless fight with developers.
Let's hear to Max Mosley(I know some don't like the guy, but, please, hear):
One manufacturer is spending a sum greater than half its total annual dividend. This is unsustainable and sooner or later the shareholders will notice." Sorry, that's not the quote... but I couldn't resist. The quote is this:
- Changes to the bodywork regulations to reduce downforce while maintaining drag levels so as to avoid an increase in cornering speeds over 2006 levels (Article 3).
Reason: Safety"
For example: all started by reduction of engines (it have been done before numerous times). What happened? Well, low speed downforce. Now we have tyres developed for that. Final result: "super speed" in curves. Without active suspension, we never have seen such friction factors on curves!
Some day somebody is going to "black out" in one:
some people say that was what they thought back in the 80's about Patrick Depailler's death at Hockenheim.
Let me quote Mansell, at the beginning of the aerodynamic debacle we have lived now for many years: "
A lot of people thought the recent San Marino Grand Prix was a sure contender for the most boring race in the history of the sport." He went on to say: "
because aerodynamics are too heavily favoured. The sport has become a victim of its own rules.". This was said a loooooong time ago.
More important for the fan: I'd say the car are starting to get ugly. Look at the development blog: EVERY SINGLE ARTICLE is about fins, ears, chimneys, platelets, wings, winglets, air boxes... Pure barroque. We have a barroque aerodynamic, clearly.
Last commentary, Falcon: can't load cells or ride height sensors transmit data to pits in real time? There is no need to wait for the end of the race, you can black flag anyone after one lap, but suit yourself: any method is good for me, pick one you like.
RH1300S wrote:... If you mandate 12500N - what if you think someone gets a reading of 12501N (or 12500.01)? ... How would you set a car up for a corner like Eau-Rouge where there is a compression and stiffer springs may be required?...
I understand RH1300 states he thinks you cannot use ride-height through Eau Rouge as a measure of downforce. RH1300, that is the reason I said you need "ride height, position and speed of the car, and profile of the track". The last three items allow you to say what happens on vertical curves. And, as an engineer, I'd say 12500.0001 N is over the limit, sorry. Surely marshalls can give you a penalty appropriate to the offense, talk to them, but engineers knows what 12500 N are and how you measure your probable error. They've done it before.
