Ferrari F2012
amouzouris
105
Re: Ferrari F2012
timbo wrote:
Crucial_Xtreme wrote:The vortices near the wishbones and the rod aren't like the ones they've got in the wind-tunnel.
Not sure how they claim to know this, nor would you think Ferrari would make such an oversight.
Nor would I think the wishbones can be enough obstruction to steal any topspeed.
+1...i think that everyone is just speculating on something that in my opinion has nothing wrong...
Sombrero
Sombrero
126
Re: Ferrari F2012
The F2012 is quite an incredible car. In a way, I have the feeling that the areo work proceed very slowly this year. Is there something very wrong with the wind tunnels in Fiorano and Köln since severals months now ? Did the Scuderia really recover from last year wind tunnel problems (model size from 50% to 60%) ?
afiq
afiq
Re: Ferrari F2012
2nd day
shelly
shelly
136
Re: Ferrari F2012
The autosprint rumor could be right or wrong, but it is coherent.
If the wt showed the engineers a certain vortex behaviour, they have built the car accordingly, and they could have discovered on track that the pattern is not the same on the 100% size car.
It is not impossible that this happened.
twitter: @armchair_aero
motobaleno
Re: Ferrari F2012
shelly wrote:The autosprint rumor could be right or wrong, but it is coherent.
It is not impossible but, in my opinion, extremely unlikely expecially when you have in that car much more evident sources of drag
elFranZ
Re: Ferrari F2012
Yes, it's possible, but remember, it's Autosprint, yesterday its director on twitter said Ferrari were running a floor-facing exhaust, and in a matter of seconds here we discovered that it was simply not true.
Ferrari having WT problems is not that news, so take it for what it is, a rumor.
Now, the question: looks like Massa is starting with yesterday configuration, can someone confirm? If so, it's not that strange, weather today should be good, so they need a new baseline.
Mazdaboy
Re: Ferrari F2012
I read, Massa try a new engine cover today.
Every race ends when the chequered flag is out!
Forza
238
Re: Ferrari F2012
Mugello - Day2 F2012 exhaust configuration (via AMUS)
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
I think you're right Shelly, it's possible. But honestly I simply rubbished it in my own mind because that publication has been on about the front suspension since Australia and have different reasons each time. I just think people have been looking for the F2012's problems, and it's easy to blame the one part that is different from the rest of the grid, true or not.
@elFranZ yes, exhaust is same as first 4 GP's.
bhall
bhall
244
Re: Ferrari F2012
Work with me here.
Red Bull's flexible front wings have long been said to provide more downforce when flexed because it puts the wings closer to the ground. This has never made sense to me, but I've kept my views to myself, because I don't always know what the hell I'm talking about, and it seemed silly to challenge the consensus view.
At any rate, the reason why it's never made sense is because I don't understand why teams would want to tack on additional downforce on straights where the wing is flexed the most, because, as we all know, downforce equals drag. A straight is the very last place on a circuit where one would want to add drag.
With that in mind, could the flexible wings actually be a way reduce drag rather than a way to create more downforce?
Everyone knows that tires are among the biggest contributors to drag on an F1 car, if not the biggest contributor of all. Because of this, teams have gone to great lengths to divert air flow around the front tires. Brawn ushered in outwash end plates on the front wings for this very reason. However, outwash end plates subtract from the total surface area of the wing itself, which means it can't make as much downforce.
Red Bull, as far as I know, never adopted outwash end plates. Instead, their wings flexed.
Imagine a clam shell and how it opens. If you get the wings to flex at speed, the end plates open just like that. This action would be very valuable if it means the new angle can divert flow around the tires.
(Click to enlarge)
Note how all of those wings feature an increasing number of (Jane, you ignorant) slots as one looks from the front of the wing to the rearmost corner of the flap. I think those (dirty, dirty) slots are what allow the wings to flex. They do so by reducing the wings rigidity in those areas. The arrangement of those (loose) slots also suggest that not only do the end plates open like a clam shell, their outward angle is also increased, which directs even more air around the tires. These effects would even seem to be amplified as speed, and thus force on the flexible portion of the wings, is increased.
It's a perfect solution. More speed = less drag.
Conversely, the leading edge of the wing remains robust so that it can shoulder the forces applied to the end plates during FIA scrutineering. You can even see how the the cascade wing supports spread those forces out along a greater portion of the wing.
Does any of this make sense, or do I need to get my doctor to up the dosage?
EDIT: This would also explain Ferrari's troubles with errant vortices. The pull rod suspension creates a wider track width when compressed. The front wings probably didn't flex enough to allow for an angle necessary to get air flow around the new width.
amouzouris
105
Re: Ferrari F2012
bhallg2k wrote:Work with me here.
EDIT: This would also explain Ferrari's troubles with errant vortices. The pull rod suspension creates a wider track width when compressed. The front wings probably didn't flex enough to allow for an angle necessary to get around the new width.
it does make sense..to me at least...one thing i said quite a while back is that when the front wing bends downwards...it needs a force pushing it...so part of the force that would make downforce is now actually 'wasted' as it keeps pushing the wing down...
.poz
.poz
51
Re: Ferrari F2012
Forza wrote:Mugello - Day2 F2012 exhaust configuration (via AMUS)
looks like this is the older (launch ?) configuration: longer acer ducts, no turning vane, no "tongue" out of the exhaustion
Yesterday exhaustion setup
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Floor detail
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
p910iFrank wrote:I am new of the forum.
I noticed that the floor in yesterday configuration had some
wings to divert gas.
Is it the floor configuration for the big upgrade that
is coming tomorrow?
I don't think that Ferrari spent two month for changing the
Exhaust system direction
Below is a image of one of the turning vanes on the floor. We're not exactly sure what's coming tomorrow. I suspect if they have a new floor ready we may see it tomorrow, although in Spain is more likely.
As for the time the team have spent on the car, it takes months to conceptualize, research, preliminary tests, prototype, test, manufacture & get ready for the car. Ferrari is a large team so there are people working on different parts of the car. But 2 months on an all new exhaust on an already bad car is about average. We will see.
bhall
bhall
244
Re: Ferrari F2012
bhallg2k wrote:[Everything I said earlier]
Never mind. Scarbs wrote of this at least as far back as January.
I'll be in the Delorean if anyone needs me.
