Could anybody tell me more about the regulation situation for these vents ?
air is coming out of there. THere is a high pressure area that builds up in wheel wells. not sure how the compare with slots ect but I would guess it has more to do with the required size being better as a large hole.Nando wrote:How is that aerodynamically compared to let´s say slots or vents whatever you want to call them?
Is air getting sucked out of there or is being pushed? Or both?
Does it really matter? The issue was that the power source was in 'proximity' of the front tyres (I do not know how many millimeters)and that led to undesirable over heating. I did not say that thing, the Speed TV commentators did last year during the race. Oh I don't know how much power they utilize, but here s an article explaining the relevance of 'why' they used LEDs and its benefits:MadMatt wrote:Do you have any values for what you are saying ? I mean, like how many Watts these LEDs produce for example ? It seems a bit too optimistic to say that the heat from the power sources of the LEDs can lead to warm the tires.
I think the rear vents are also to reduce life and maybe optimize the drag around the rear of the car, but for sure some people "in" aero will say something about this.
But that discussion should maybe be moved in the "aero" section of the forum, isn't it ?
Highly doubtful. The LEDs require cooling ducts, but I'm 99.999% sure the teams have no love for the BHHs and would go back to vents in a New York second if they could. No one really wants high pressure lift under in the wheel arches negating downforce, and will do their best to eliminate it but not to this extent as it's probably pretty draggy.MadMatt wrote:Do you have any values for what you are saying ? I mean, like how many Watts these LEDs produce for example ? It seems a bit too optimistic to say that the heat from the power sources of the LEDs can lead to warm the tires.
