Ferrari F2012
Froggolo
Froggolo
Re: Ferrari F2012
hello
does someone have data about Ferrari's top speeds and other cars?
is there some improvement in this too?
Relax, man. Have an elliptical drink or something® ( bhallg2k )
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
It seems they have ditched one of the slots ahead of the rear tyre. It looks like there's only 2 slots now instead of 3.
The FWEP's look new, but I'm not positive.
And I believe the sidepods are slightly different than the older ones. A little more undercut towards the rear end side of the Shell logo.
The new diffuser is similar to the one ran in pre-season at Barcelona but still different from it. Same vortex generators but indents on the gurney flap and the strakes are way differently shaped than anything before.
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Teechnical wrote:Forgive me for another newby question but you'd have to run as low rake as you possibly could to seal the diffuser?
Is that correct?
Not if you can get the exhaust gasses to the edge of the floor beside the rear tyre. It's less powerful than last year but teams are trying it. If a team can get said seal, they can run more rake. But Ferrari has abandoned this route and went for a more neutral exhaust position.
Nando
Nando
Re: Ferrari F2012
Is that correct?
I think the diffuser works at a certain height the best.
IF you go above that you will loose downforce but if you manage to seal the diffuser with the exhaust gases you can then raise the diffuser and thus create a bigger "virtual" diffuser, and you also have the front wing closer to the ground which will produce more downforce.
So you could probably say that the car with the most rake also has the best exhaust solution to sealing the diffuser. might be wrong though :)
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Larger shot of new diffuser. Very large so to save bandwidth I'm just linking the picture.
http://www.formule1.nl/media/uploads/me ... 073.46.jpg
f1316
f1316
82
Re: Ferrari F2012
f1316 wrote:
ferrulin wrote:Spanish Diario AS talks about Ferrari showing a new exhaust configuration to seal the diffuser by using the coanda effect but in a configuration different to Mc, RB or Sauber...
http://www.as.com/motor/articulo/efecto ... imot_1/Tes
Very interesting. Do these "slots" sound to anyone else like the evolution of this exhaust placement that scarbs was suggesting? (will try to find the link)
This was the picture I was thinking of:
http://scarbsf1.files.wordpress.com/201 ... 12_alt.jpg
I don't see any evidence of this evolution so far, but that's to be expected. Will be interesting to see if they go in this direction in future sessions/races.
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Interesting piece of carbon close to the top wishbone near the exhaust. It almost looks like an exit of some sort no?
Nando
Nando
Re: Ferrari F2012
Cool opening on the floor to the right of the tire.
Edit: Also, is the little "out-take" in front of the exhaust new?
(between exhaust and Fiat logo)
Edit2: Exhaust housing looks new, no third slot behind the exhaust tip.
bhall
bhall
244
Re: Ferrari F2012
Crucial_Xtreme wrote:Interesting piece of carbon close to the top wishbone near the exhaust. It almost looks like an exit of some sort no?
I noticed that yesterday when it was blanked off. It seems they're opening up pretty much everything the rules will allow.
timbo
timbo
111
Re: Ferrari F2012
So, no new nose? What jurno's were talking about?
.poz
.poz
50
Re: Ferrari F2012
Crucial_Xtreme wrote: Not if you can get the exhaust gasses to the edge of the floor beside the rear tyre. It's less powerful than last year but teams are trying it. If a team can get said seal, they can run more rake. But Ferrari has abandoned this route and went for a more neutral exhaust position.
But the new carbon black zone under exhaust - ex acer duct can be an hint that at some speed exhaust plume or a part of it goes there by coanda effect/ or lower pressure
Or maybe it's just aesthetic
FakeAlonso
Re: Ferrari F2012
p910iFrank
p910iFrank
Re: Ferrari F2012
Any info about the Ferrari TOP Speed?
Mui
Mui
Re: Ferrari F2012
p910iFrank wrote:Any info about the Ferrari TOP Speed?
Here you go.
http://www.formula1.com/results/season/ ... _trap.html
You can also see sector times through the drop down menu.
Was Massa using the same car?
FakeAlonso
Re: Ferrari F2012
Pos No Driver Time of Day Speed
1 9 Kimi Räikkönen 10:46:08 318.2
2 12 Nico Hulkenberg 11:23:19 317.9
3 11 Jules Bianchi 11:19:22 317.4
4 10 Romain Grosjean 11:31:24 317.2
5 8 Nico Rosberg 10:45:26 316.6
6 7 M. Schumacher 11:14:31 316.6
7 20 Alexander Rossi 10:56:14 315.6
8 21 Vitaly Petrov 10:46:05 315.4
9 5 Fernando Alonso 11:24:04 314.3
