For theory sake let's suppose FIA allows actively adjustable suspension.
You can actively adjust camber, caster, toe in/out, anything.
Would you still require a rigid chassis?
Would active suspension adjustments compensate chassis flex?
Perhaps the best analogy I've heard.xxChrisxx wrote:It would be like having a gyrostabilised gimbal tea tray carrier to prevent your freshly brewed hot tea from spilling. Then making the tray from jelly.
Absolutely,,,you have to have an dead rigid base.If anything you'd want a more rigid chassis with active ride
Not doubting your position, just trying to elicit a little more understanding of the issue from you.DaveW wrote:Brian: I'm afraid the world is a little bit more complicated than you have assumed, as g-force hinted in his post.
The drivers hated the active suspension cars because the were so stiff and rode so hard they were beated and bruised by the end of a race and just praying for it to be over.Surely the main point of active ride in F1 was to eliminate the need for such hard suspension
I don't think that is quite correct... I believe the Tornado terrain following system had similar characteristics, & was probably earlier.Tommy Cookers wrote:...the only real Active Ride vehicle ever is the Rockwell B-1B
Again, sorry to disgree, but the Lotus Active system had a good ride. Senna remarked that he no longer had to bandage his hands, & I ran a road vehicle fitted with the 'T99 system for development purposes, and it was acceptably comfortable. I can't comment on the Williams system, however.strad wrote:The drivers hated the active suspension cars because the were so stiff and rode so hard they were beated and bruised by the end of a race and just praying for it to be over.
It wasn't earlier, but I'm not entirely sure that was the reference anyway.DaveW wrote:I don't think that is quite correct... I believe the Tornado terrain following system had similar characteristics, & was probably earlier.Tommy Cookers wrote:...the only real Active Ride vehicle ever is the Rockwell B-1B
