It is true that hydaulic actuators are normally position controlled, but only by virtue of a position control loop. Intrinsically, they generate an actuator velocity proportional to drive current.Tommy Cookers wrote:... and using real position sensors (surely the actuators are more naturally position controlled devices).
In our case, the control code was arranged to generate actuator velocity demands for each corner. These were used to drive idealised model actuators, the position outputs of which fed positions back into the control code. As a separate task, model velocities & positions were used the drive the actuators themselves. There two reasons for this strategy: it minimzed possible coupling between the control code and temporary actuator shortcomings, & it provided a way of detecting actuator faults by comparing differences between model & actuator positions.
The system transport delays were something of a problem, and electromagnetic actuators would have made life easier. They have two problems, however, the size & weight of the power amplifiers & the fact that they are not good at supporting steady state loads.xpensive wrote:I think it all depends on from where the feed-back, or "is-value", is taken, ground-clearance sensor or something else, but either way, the draw-back with hydraulics is always speed. Ideally electro-magnets would probably the way to go, which is something that has been tampered with on valve-trains, but at a terrible energy-price.
Total delay of our system was the sum of transducer filters, code delays (the time required to response to an input), and actuator delays. Transducer filters were set at 100 Hz (2-pole), and the actuator delays corresponded to filters of around 200 Hz (roughly). I worked hard on control code layout & achieved an additional transport delay of around 150 microsecs. The system was reasonably responsive, repeatable & robust.
The '99T worked well on "mechanical" circuits (it won at Detroit & Monaco in the capable hands of Senna). Performance suffered in high downforce circuits (not working the tyres hard enough, we decided - probably not helped by lack of aero). We should have won at Monza (a low-downforce circuit), but Senna fell off overtaking a lapped car. He was adamant that was caused by the system - it is possible that the lateral balance algorithm caused the car to three wheel at the limit (it was known to have a poor natural balance). That race was won by a jubilant Williams team - their first win using an active system. Senna recovered from the sand trap & finished a distant second.Tommy Cookers wrote:The real problem is having at all times the right (position?) demand signal for each actuator ? This will take some development I think. This was the critical factor with the Lotus ?
We ran 3 cars (2 & a spare) for a whole season. Whilst we experienced the odd problem in testing (some self-inflicted), we only suffered one DNF. I recall that was caused by an electrical failure after an errant piston severed a cable loom. We suffered a major oil leak courtesy of a factured coupling at Imola - Senna finished second after running out of fluid 6 laps from the end.
Edit: I should down-play my DNF claim - I think it was 1 active system-related DNF, apologies.
