That would be obvious, but what marcush mentioned is the shock/bump load, which is what you fear with Euler.dren wrote: ...
They will see compression forces when cornering in both push and pullrod set-ups.
Is that the pullrod relative to the chassis or suspension arms?xpensive wrote:That would be obvious, but what marcush mentioned is the shock/bump load, which is what you fear with Euler.dren wrote: ...
Don't get the question there really, but the stretching force in the pullrod, must of course be equalled by compression forces in the arms. In a pushrod application it's the other way around, which is just one of the reasons I find it preferable.dren wrote:Is that the pullrod relative to the chassis or suspension arms?xpensive wrote:That would be obvious, but what marcush mentioned is the shock/bump load, which is what you fear with Euler.dren wrote: ...
I think tahn next season we will see more pull rods, not only on Ferrari.Crucial_Xtreme wrote:There is absolutely no reason to think they're changing back to push-rod. Why would they? The current pull rod setup works well. The front suspension is not Ferrari's problem.munudeges wrote:At the risk of pouring a little oil on the fire ...
It's certainly a possibility, and it's very interesting to see the Ferrari continue to do well despite this perceived handicap. Shows that it really isn't getting in the way like some members insist just because it looks a bit funny to them.Mr.G wrote:I thing next season we will see more pull rod, not only on Ferrari.
I should note that none of these features are a given; that is, none of them are inherent to the design. You can design a pullrod system where, as compared with an equivalent pushrod system, none of these points are true.n smikle wrote: Pull rod gives lower CoG
More difficult to access (to change settings)
A cleaner air flow path is achieved near the midline of the car.. and a better air flow near the lower end of the brake ducts.
Pull rods are lighter (in theory at least) and take up less volume.
