Ferrari F2012
GTO
Re: Ferrari F2012
hardingfv32 wrote:What would happen to the flow on the section of white barge board that is 90 deg to oncoming flow? Would the flow just trip over it? Seems like there would be a lot of turbulence.
Brian
Brian, look at this pic.
Image[/quote]
The front wing is "managing" the air flow up (into the wishbones & further into the rad opening) & to either side (around the tire & under the nose or beside the nose uprights). Air does not hit the bargeboard directly (90 deg. to it) from the front.
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
A few shots from today
FakeAlonso
Re: Ferrari F2012
amouzouris
105
Re: Ferrari F2012
doesn't the new exhaust look lower down than before?
FakeAlonso
Re: Ferrari F2012
amouzouris wrote:doesn't the new exhaust look lower down than before?
I think is the same only with small changes
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Some pictures make it look that way, but after looking at pictures from Canada I don't believe so. I think the only real difference is the cooling vent/slot
amouzouris
105
Re: Ferrari F2012
cooling vent slot and a different angle of the channel...it is looking a little bit more outwards
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
amouzouris wrote:cooling vent slot and a different angle of the channel...it is looking a little bit more outwards
I've been discussing this with others. I'm not so sure the channel angle has changed.
Canada
Valencia
Canada
alogoc
alogoc
-10
Re: Ferrari F2012
Is there a change to the suspension?
THE F2012!
THE CAR THAN WON 2012 WORLD F1 CHAMPIONSHIP WHIT A TILTED ENGINE!
Nando
Nando
Re: Ferrari F2012
I thought at first the housing was lower but now it´s fairly clear it´s identical except for the vent.
Same distance as well. (to the driver)
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Nando wrote:I thought at first the housing was lower but now it´s fairly clear it´s identical except for the vent.
Agreed. At first I thought it may have been moved back towards the driver a bit, but it hasn't. Many are convinced it's a new exhaust but it's not other than the vent.
@alogc It's virtually impossible for us to know if there is a new suspension.
PistoneRovente
PistoneRovente
Re: Ferrari F2012
Valencia Thursday
JRodrigues wrote:Image
In my opinion this isn't the same exaust used in FP2, the reason why we saw a vent is because they cut a vent into the old (Canada) one
Valencia FP2
alogoc
alogoc
-10
Re: Ferrari F2012
it's slightly different!
THE F2012!
amouzouris
105
Re: Ferrari F2012
i think its slightly different too...and Tombazis said that they were going to bring some different exhaust versions here as well...and i don't think he only meant o small cooling hole...
Nando
Nando
Re: Ferrari F2012
Must be internally then as it looks like a carbon-copy of the Canada exhaust minus the hole.
