Could be a housing for the eventual DDRS system in preparation for Monza?alogoc wrote:the difference is in that black cover
GB
http://kepfeltoltes.hu/120705/423_mediu ... es.hu_.jpg
Valencia
http://www.motorsportgp.pl/images/motor ... 12-032.jpg
GB
Valencia
That was fast =D> thank you bhallg2k, i always thinking they try to make more pressure on the flap, like when you open the car window comes wind inside...bhallg2k wrote:They reduce pressure that would otherwise be released in the form of drag-inducing vorticies from the corners of the wing.
how on earth do you fix thhat???f300v10 wrote:Quotes of 'trying to repair Fernando's front wing' imply they only have 1 copy of the new FW per driver.
...or Massa is going out on the old oneLionKing wrote:If there is only one new FW per driver, it means that they will be fixing Felipe's wing actually
