I have applied a pressure on the throttle body side and I want to get the flow rate of 1 channel after another (like you have to test). The values are realistic but the difference between the channels doesn't match the experimental test conducted on a flow bench !
I will have to check how I have conducted the test with CFD because at the moment I do not remember all the parameters (it was months ago)
But here are 2 pictures for you :
1) This is the standard part, including the plenum, the intake and the throttle body
2) This is the standard part but with a "Swedish" type plenum
I have seen improvement with the swedish plenum of course, but the values of the different cylinders are too close to be true (especially from the standard part which I was able to test). So this is why I hope that a member could test the 1st part and tells me what results he gets so I can hopefully see where I made a mistake. I've tried different configuration parameters as I remember, including variation of the boundary layers (from 2 to 5) but without dramatic changes.
