I would actually think, that the way it works would be the other way round. At first we need to assume, that the hole in the main plane is on the top in the shadow of the flap and below the T of the Lotus sponsoring.Cuky wrote:Why do you thing they are blowing down in to the diffuser??Kiril Varbanov wrote:
This is their way of making a passive F-Duct. While they can't get airstream to the wing through shark fin, as they are forbidden to contact with rear wings, they have routed it through central pylon. When duct is not activated air goes from intakes straight to the exit in the middle of the car, just under the beam wing (that large tunnel marked here in blue). When car is at certain speed F-Duct is activated and air goes from intakes, through central pylon and on to the wing. I am not sore where they are venting it, though I don't think it will be too long until someone spots that place
Then when the DRS is closed, there is a relatively low pressure at the and of the hole and through the duct comes high pressure --> the air flows through the main plane.
When the DRS is open, then there is a relatively high pressure on the end of the main plane --> not much air is flowing through the ducting and the wing may stall.
