Actually, the regulations do assert such control in a way.hardingfv32 wrote:The FIA is not going to control the max torque at a given RPM. That would be impossible to administer. Are you going to have the FIA telling the teams that they can do better with their engine performance and that they will be in breach if they do not make the FIA target torque number?
For any given engine map used during a race weekend, of which two are allowed (dry/wet), 0% accelerator travel must coincide with 0% torque demand as defined by that map, and 100% accelerator travel must coincide with 100% torque demand, again, as defined by that map. Additionally, engine maps must be implemented in such a way that power output is uniformly linked to accelerator travel to within 0.030Nm/RPM. The engine map used during qualifying must be used during the race.
Those rules do not apply when the engine is at idle, which is 5,000 RPM max, and when the engine speed is above 15,000 RPM combined with accelerator travel greater than or equal to 80%. Teams are given some freedom to adjust engine mapping in those ranges for the purpose of increasing engine reliability. I believe Red Bull is taking advantage of those allowances to gain a performance advantage in much the same way engine manufacturers gained power through modifications made for the sake of "reliability."
