bhallg2k wrote:
To assert overall compliance, they likely defined "monotonically" as "always increasing," just as you and others have, despite the "spirit of the rules" defining "monotonically" as the requirement for the rate of increase. Because both definitions are valid, the stewards had no choice but to allow it, even though they openly acknowledged that Red Bull's logic was improper.
well, I hardly ever side with Brian on many things, but I would say, that he and RBR are not alone in their definition of "monotonically increasing".
![Image](http://upload.wikimedia.org/wikipedia/commons/thumb/3/32/Monotonicity_example1.png/220px-Monotonicity_example1.png)
A monotonically increasing function. It is strictly increasing on the left and right while just non-decreasing in the middle.
according to
this
If they (FIA) wanted a linear relationship or constant gradient (not necessary linear), they could/should have better defined it.
But I don't think, that "max. theoretical torque" or what ever terms are used here, come into this at all.
I think, the rules just states, that in case the driver puts the pedal to 100%, you have to "request" >>equal to or greater than the maximum engine torque at the measured engine speed<<, meaning , you have to ask for more (or at least the same) then you currently have at this engine speed (rpm).
and as the rule mentioned by the FIA deals either with 100% throttle or o% throttle, the whole "monotonically" argument is a bit mood, as the pedal is at 100% already, therefore I still think that bhallg2k original thought, about the 15-18k rpm range "trickery" (for want of a better word) holds some water, and sounds plausible/likely to me.
I don't think anyone will ever made a big fuss about a competitor, who just decides to bring a less powerful engine to an race. That doesn't makes any sense.
maybe someone, can have a look, what the engine rpm range is (maybe onboard lap from Vettel or whatever), which the car uses in the individual gears. What is the lowest rpm used on the track (after an upshift)?
