I Dont know if its legal or not, but an article about similar thing in W02, which they tested at Japan 2011Huntresa wrote: How does it show that, also that is illegal...
What about the pic i posted from Hungary 2012 friday free practice? you can clearly see 2 tubes coming from the tip of noseHuntresa wrote:That system is still illegal and thats why they arent using it, they tried it in Japan just to see if they can stall the FW and gain something from it and i guess they found they could so they built a legal version.
Then why should the tube come all the way to the tip of the nose? see the pic i postedJackles-UK wrote:Aren't those just the tubes coming down from the rear wing as part of the 'original' DDRS?
siskue2005 wrote:Then why should the tube come all the way to the tip of the nose? see the pic i postedJackles-UK wrote:Aren't those just the tubes coming down from the rear wing as part of the 'original' DDRS?
If it was just DDRS it should just turn down to the wing pylon and go to the wing to nlow it
but here there is an extra 2 tubes coming from the tip of nose!
It is illegal, you arent allowed to use the hole at the nose for anything else then cooling for driver.yener wrote:Pfff come on guys. Read the earlier posts and you will find out why the tubes are there. It's not illegal btw.
Yeah.bhallg2k wrote:I've always maintained that any front wing vents on the W03 are fed from the scoop on top of the chassis. Legality aside, it's solution that makes sense for its purpose.
But we've seen the tubes coming from the rear wing over the gearbox and along the sides of the car into the nose cone. I don't see why they would use the scoop or why there isn't any ducting for it in the nose cone or bulkhead.bhallg2k wrote:I've always maintained that any front wing vents on the W03 are fed from the scoop on top of the chassis. Legality aside, it's solution that makes sense for its purpose.
