slits there would definetely not cause sepeartion in that are.
I am extremely confident in that it is flow seperation due to the pillar.
What slits? I have the Hi Res image if you zoom into the area that's highlighted there are no slits....PhillipM wrote:That's a massive section of flow seperation from that pylon if it is, I'm not buying that, I still think the vertical slits in the pylon are blowing there to cause the seperation.
Matt Somers wrote: What slits? I have the Hi Res image if you zoom into the area that's highlighted there are no slits....
Lotus have already stated it uses the same loophole in the regulations as mercedes DRS system, and they said it works with the drs system,bhallg2k wrote:There are no DRS inlets like the ones seen on the W03. This system is purely passive.
Air is collected by the airbox scoops and directed to the engine cover vent/wing duct assembly. At a certain pressure threshold, the air flow through the duct is sufficient to cause separation. It's a simple little thing to gain a little bit of time.
If the regulations still allow it, you'll see full-on Daffy Duct implementations up and down the grid next year when they can be incorporated into designs from the very beginning. Until then, they'll look like this.
yes it works, but it dose not depend on the drs system, their system working even when drs system is disabled. mercedes drs system working only with drs turn on,there for create double effect. lotus system working when drs is turn off (creating downforce), and when is turn on (creating same double effect like on mercedes). I can't explain better than this.N12ck wrote:Lotus have already stated it uses the same loophole in the regulations as mercedes DRS system, and they said it works with the drs system,bhallg2k wrote:There are no DRS inlets like the ones seen on the W03. This system is purely passive.
Well yeah it uses the same loophole, but that loophole is just to use the DRS for a 2nd action, and werent you the one that said there were no holes ?N12ck wrote:Lotus have already stated it uses the same loophole in the regulations as mercedes DRS system, and they said it works with the drs system,bhallg2k wrote:There are no DRS inlets like the ones seen on the W03. This system is purely passive.
yes I couldnt find any initially, however I have now found one, so I have revised my theory, at least I am trying to come up with some workable explanation, the holes which people had 'found' before were not holes, we now know this is a hole, so I have now offered a theory above, I believe my theory is workable,Huntresa wrote:Well yeah it uses the same loophole, but that loophole is just to use the DRS for a 2nd action, and werent you the one that said there were no holes ?N12ck wrote:Lotus have already stated it uses the same loophole in the regulations as mercedes DRS system, and they said it works with the drs system,bhallg2k wrote:There are no DRS inlets like the ones seen on the W03. This system is purely passive.
