Yes. Not only that, but I think we're likely to see teams at least testing derivatives of this system - I've decided to call it VD, by the way - at Spa and Monza.
The more I think about it, the more I see how the effects of a VD might be rather profound - you should now clearly see why I've dubbed it VD - because it has the potential to virtually eliminate unwanted rear-wing drag from a car's aerodynamic profile.
As a car accelerates and requires increasingly smaller levels of downforce (and becomes increasingly sensitive to drag), the system sheds a corresponding amount of downforce and, more importantly, its associated drag. Later, as the car slows down to take a corner, the system then re-establishes downforce proportionally.
In a weird context that perhaps only makes sense in my head, a VD creates a stealth wing, because the vented flow is essentially an invisible, self-adjusting aerodynamic device.
n smikle wrote:I did some simulations last night.. the model is a bit incomplete because I did not put the slits in the end-plate. but anyway, before and after tests show that the slits reduce the Down-force and drag.
I will post some picture tonight after work.
The downforce drasticallty drops...And this is when all the air from the scoops is blown through the pylon slits. Remember though, I have not modelled the end-plate slits yet. I do not know how that will affect the model. Will do that tonight
I eagerly await your data. Just remember that the lower vent is absolutely vital to the functionality of a VD. It must extract enough air so that the system doesn't become completely pressurized and choke. Otherwise that would occur very quickly given the diminutive size of the duct's slits versus the amount of air the scoops take in.
