Shape! Due to profile, the air on each side goes at a different speed, pulling car onto track. Look at an aircraft wing (in reverse) It creates lift, even when the plane is flying level. I presume that 'camber' refers to the amount of curvature. The greater the curve, the greater the downforce.
Without seeing the flap in profile it is almost impossible to determine the upper and lower cambers, if the camber is symmetrical it will be aerodynamically neutral at 0 degrees.
To my eyes it looks like the flap is symmetrical and aerodynamically neutral. IMO this would make sense because you could then easily determine if the flap produces downforce/lift or has no affect simply by changing its angle when open. presuming that is legal of course.
