astracrazy wrote:that's a good point regarding the testing conditions.
So how does it work with regard to different tracks then?
I'm not sure I understand the question? How do we calculate lap-times for each track? Each track on Virtual Stopwatch has its own set of curvature and distance data. The program uses this data to determine the speed at each point on the track by calculating all the forces that are acting on the selected vehicle, and from there it determines the lap time. The special version for the championship replaces the F1 car model's aero data with an aeromap generated from the CFD test of each car.
This means, for instance, that a track like Monza will favour lower drag over higher downforce, and monaco favours high downforce over higher drag; just like the real laps. You can try a demonstration version of the standard F1 variant of Virtual Stopwatch online by following the link in my signature.
Does that answer your question?
