turbof1 wrote:[...]
My guess is that due that pipe being behind the roll hoop and engine cover, that the free stream flow isn't affected as much the discharged flow.
This is a rather good image of the intakes:
[image]
I don't think the air box or its peripherals have the dramatic effect downstream required to mitigate the effects of the free stream on flow discharged from the VD. Otherwise, they would have stuck with the "blade" roll hoop on principle, don't you think? It would also mean the overall effectiveness of the rear wing would be diminished, which could be the case anyway.
It will be interesting to see how this pans out, because I'm not so sure the Lotus VD works at all. The concept is simple; implementing it, however, is decidedly complicated.
Maybe all that was needed was this concept of detaching the duct from the wing. Maybe it's just a dead-end development path.
(Maybe the guys at Lotus are snickering right now. "Oh, God, they bought it! They really bought it!")
