I wonder if Williams can incorporate their flywheel into a system with the turbo... That might just be a HUGE advantage for Williams due to the amount of development that they already have in this unit.aussiegman wrote:IIRC the TERS allow a single turbine so no separate systems.
This is one of the main reasons why I think that a single turbo charger with an electrical CHRA generator/motor unit will be the system that is most utilised.
It has significant advantages from a packaging (weight & size), power output, robustness and thermal energy recovery standpoint as well as being a very mature and well understood technology (so cost effective). The primary issue has previously been the thermal insulation of the CHRA electrical motor/generator, however I have seen a number of systems where this has been mostly overcome.
Wiliams' flywheel is simply a system for storing electrical energy, and that is independent of where the energy comes from. And in that terms it is worse than batteries, because it has a very strict resulting it bad packaging and high CoG (in contrast to batteries that can be made thin and spread about on the floor).Wideband mindeD wrote: I wonder if Williams can incorporate their flywheel into a system with the turbo... That might just be a HUGE advantage for Williams due to the amount of development that they already have in this unit.
I'm pretty sure the MMC used isnt terribly heavy, and they are going to have to incorporate a MGU into the turbo to spool it up.superdread wrote:Wiliams' flywheel is simply a system for storing electrical energy, and that is independent of where the energy comes from. And in that terms it is worse than batteries, because it has a very strict resulting it bad packaging and high CoG (in contrast to batteries that can be made thin and spread about on the floor).Wideband mindeD wrote: I wonder if Williams can incorporate their flywheel into a system with the turbo... That might just be a HUGE advantage for Williams due to the amount of development that they already have in this unit.
Whatever storage they use they won't put it directly on the turbo (very high CoG). And they won't use their flywheel for storage, but batteries.
Just to clarify this:Wideband mindeD wrote: I'm pretty sure the MMC used isnt terribly heavy, and they are going to have to incorporate a MGU into the turbo to spool it up.
The flybrid technology downsized and fit into the turbo would simply replace the MGU, and it obviously is already designed to accept power to spin up, and convert that spin back to electricity.
I think if Williams isnt looking into this, they are missing a big opportunity.
Flybrid is a company with a product: http://www.flybridsystems.com/F1System.htmlWideband mindeD wrote:i would integrate it betweeon the snail casings on the hot and cold side of the turbo unit. And I believe the flybrid is made of a magnetized MMC that will spin up if electricity is applied, and decelerate with an electrical load attached.
Maybe that was a different type of MMC electromechanical flywheel? I know i read a post early on about a few of them...
And all f1 cars can have flywheels, they just cannot use them for KERS. Actually, I'm kind of surprised that they dont use Laptop HDD sized flywheels for gyroscopic control.
But then it would function like an electric motor. So what you propose is, that they use an electric motor with added inertia and weight (i.e. a flywheel)?Wideband mindeD wrote:@Superdad
You said the williams flywheel stores energy when electricity is fed in over a wire.... That is exactly what I am saying. If they could put it between the compressor wheels on the same shaft it would be able to be increased in speed by applying electricity, and decelerated with a load, generating electricity...
Faster spool up, or reclaim electricity.
I am rather sure that they are using electric motors to spool the turbo anyways, that is why I think WIlliams could really be ahead on this if they incorporated the flywheel into the turbo unit itself.superdread wrote:But then it would function like an electric motor. So what you propose is, that they use an electric motor with added inertia and weight (i.e. a flywheel)?Wideband mindeD wrote:@Superdad
So your flywheel idea is, just do add inertia to the turbocharger mechanism. It will slow down any loss of rotational speed, but also any gain of it. Without a coupling mechanism to the turbine-impeller axis this is all it can do.Wideband mindeD wrote: I am rather sure that they are using electric motors to spool the turbo anyways, that is why I think WIlliams could really be ahead on this if they incorporated the flywheel into the turbo unit itself.
It may also help with any harmonic dampening at the high RPM that turbos spin.
Wideband mindeD wrote:I guess I may be looking at it incorrectly...
I see it as just another wheel on the turbo shaft (about 4 inches round), between the hot and cold side. It would have roughly the same diameter as the turbo impeller and exhaust turbine, and spin on the same shaft. To me, that allows you to NOT require the external electrical assistance that the rules allow. I think it would allow you to have far more precise control of the unit.
Even if its rotating mass is a bit more, it shouldnt really change the operation. By allowing a constant electrical input into the flywheel, i believe that you can negate the negative intertial effects by applying a set voltage to boost the exhaust power on the turbine. I am not sure of the efficiency, but this may be one of those places where you can use it like a closed loop KERS. IF you can input electricity to spool it up, use it to generate electricity during high exhaust output, and store it in a capacitor until the next electrical boost is needed...
Obviously, it would be tied into the overall charging scheme, but I can visualize what this unit would look like, and that would be VERY close to a OEM turbo housing. But, once again, it could all be a moot point if they are looking at adding clutches to isolate the hot from the cold side of the turbo, because any contraption to do that would be necessary to place right where I am picturing the flywheel...
