I have once, absolutely fantastic experience. Mind you, my ride was nothing close to an F1 car.Nando wrote:I haven´t driven the real thing
I'm not saying you did. It was just my confused answer to the following quote:Regarding Degner being flat, not sure why you even state such an obvious fact.
I know i never claimed it to be flat.
My reaction was basically, as you put it...Nando wrote:You have to back off slightly, impossible to take it flat.
I'm still sold on that the brakes aren't just crucial to slow you down - but to load the fronts to help turn in. But yep - let's agree to disagree.Let´s just agree to disagree, we won´t get anywhere.
Isn't brake bias changing evidence of this?raymondu999 wrote: I'm still sold on that the brakes aren't just crucial to slow you down - but to load the fronts to help turn in. But yep - let's agree to disagree.
Indeed, I was just saying that the existence of adjustable brake bias and the way it affects the the weight shift of the car under braking could be a testament to your theory that brakes do more than simply make the car slower.raymondu999 wrote:I'm not talking about brake balance as such - but rather, using the braking to shift the weight forwards and get the nose to dive - the extra vertical loading on the front helps the nose tuck in to Turn 2, which by extension means you can apex and exit Turn 2 quicker anyways.
The way you trail brake into Turn 2 at Suzuka, in my view - is crucial to carry the momentum through into the Esses.
this is incorrect a front bias car will work the fronts just as much as a perfectly biased car. the weight transfer will be the same.GrizzleBoy wrote:Indeed, I was just saying that the existence of adjustable brake bias and the way it affects the the weight shift of the car under braking could be a testament to your theory that brakes do more than simply make the car slower.raymondu999 wrote:I'm not talking about brake balance as such - but rather, using the braking to shift the weight forwards and get the nose to dive - the extra vertical loading on the front helps the nose tuck in to Turn 2, which by extension means you can apex and exit Turn 2 quicker anyways.
For instance, front biased brakes will cause he rear to push into the front and cause produce more load for the front tyres as the car tilts.
Whereas rear biased brakes will cause the rears to be "dragged" as he fronts attempt to keep going (relatively), therefore creating less of an overall balance/weight shift in the car under braking.
Can you elaborate?flynfrog wrote:this is incorrect a front bias car will work the fronts just as much as a perfectly biased car. the weight transfer will be the same.GrizzleBoy wrote:Indeed, I was just saying that the existence of adjustable brake bias and the way it affects the the weight shift of the car under braking could be a testament to your theory that brakes do more than simply make the car slower.raymondu999 wrote:I'm not talking about brake balance as such - but rather, using the braking to shift the weight forwards and get the nose to dive - the extra vertical loading on the front helps the nose tuck in to Turn 2, which by extension means you can apex and exit Turn 2 quicker anyways.
Until you reach the point of too much rear bias you will be using 100% of the front tires. You are simply trying to dial in just enough rear bias to fully utilize them without the rears locking first. The rear brakes have nothing to do with weight transfer until you get too much rear bias.GrizzleBoy wrote: Can you elaborate?
I think if Jenson Button is saying he will help Lewis, then Webber will have to step up and help Vettel too - not only is Vettel closer a challenger to Alonso than Hamilton is, but the gap in points at Red Bull (Vettel is 33 ahead of Webber) is greater than that at McLaren (Hamilton is 23 ahead of Button).aero expert 807 wrote:Vettel is the nearest challenger to Alonso.
Because of this the team will do everything they can [including team orders] to get him win.
How about assuming no locking? Say you had 100% threshold braking, sans locking. How would the weight transfer differ at the different levels of braking bias?flynfrog wrote:Until you reach the point of too much rear bias you will be using 100% of the front tires. You are simply trying to dial in just enough rear bias to fully utilize them without the rears locking first. The rear brakes have nothing to do with weight transfer until you get too much rear bias.
I concur. Red Bull likes winning. This season hasn't been the sweep it was in 2011 or even 2010. With the field as close as it is, the Red Bull will want to keep Vettel on the top step with Webber using his Aussie grit to hold off everyone else. They have both honor and financial future to consider if they don't make it a habit of winning with a nice dual-championship hat trick.aero expert 807 wrote:Vettel is the nearest challenger to Alonso.
