Ferrari's new suspention for China will use an ingenious method of controlling the suspention damper settings. The particles contained within the fluid/oil within the damper are responsive to electrical voltage and changes viscosity of the fluid based on the setting of the voltage regulator. In a way Ferrari are allowing the driver to change the way the suspention treats the tires on the fly. They can quicken or slow the damper resonse rate.
Active suspention is illiagal as I understand it. Active would mean that the suspention would be self-governing and self adjusted. If at any point, a human has to act to make the change, it's not "active" anymore and dependant on human input.
This is interesting, becuase in a way Ferrari are working around the rules of "park ferme". They can qualify on super soft rubber and set the suspention to take the biggest bite out of the tires, but during the race, change the damper setting to allow for minimal tire ware by sacrificing speed. We don't know if this can be done by the "driver"? or during a "pit stop". Regardless, this would be a huge advantage over the other teams.
I don't see that this breaks any rules as wings and tire pressures can be adjusted during pit stops. And in fact they are not changing any moving component, but are simply changing the viscosity of the oil in the damper.
