Not sure, RBR was faster in the race too.aleksandergreat wrote:1st Anyway F2012 needs DDRs sys to improve car performance...
word is they had A LOT of trouble whit development and manufactoring of new exhaust/sidepod,postponing a few times!Nando wrote:That´s an interesting thing.
However, with the recent correllation issues, the 54 different front wings, taking on such an advanced aerodynamic component seems like it could be the wrong move for Ferrari.
Creating a tunnel and making that work pretty much out of the box is going to be very hard, we saw how much trouble Red Bull had before they finally cracked it.
On the contrary i say bring it on, i love seeing F1 updates and this would be awesome to see how Ferrari designs their own tunnel system.
But in Q they must take front grids positions... Maybe even infront off the Bulls under pressure its much easier to make misstake... Is much easier to defent your position than atack it!timbo wrote:Not sure, RBR was faster in the race too.aleksandergreat wrote:1st Anyway F2012 needs DDRs sys to improve car performance...
Scarbs wrote:Red BUll DDRS: having pole position and managing the race and tyre wear from the front is a strong strategy. Having DDRS will only aid the team in qualifying with almost not performance penalties from having the system fitted.
amouzouris wrote:i've just thought of something...autosprint says the new exhausts will look like the Red Bull ones...so about half the sidepod will be changed if it is true...if the new exhausts were indeed designed for the F2013 or what the car will be called next year..then to be compatible with this year's car then the cooling configuration must be very very similar...so is this a hint the oil cooler above the gearbox will be retained? i thought that they would go back to a regular configuration for next year for a lower center of gravity and better mechanical grip..
i don't think it is as simple as testing a concept...to get an upgrade in performance and a reduction in lap time the bodywork, the shape etc. must be right.. the bodywork is also limited by what there is below...engine radiators gearbox etc. taking the 'concept' and adapting it to this year's car would be a lot of work...now if they started working on adapting the concept towards the end of the summer then it might be feasible...but i don't think that they had next year's exhaust finalized in the summerHolm86 wrote:amouzouris wrote:i've just thought of something...autosprint says the new exhausts will look like the Red Bull ones...so about half the sidepod will be changed if it is true...if the new exhausts were indeed designed for the F2013 or what the car will be called next year..then to be compatible with this year's car then the cooling configuration must be very very similar...so is this a hint the oil cooler above the gearbox will be retained? i thought that they would go back to a regular configuration for next year for a lower center of gravity and better mechanical grip..
If the exhaust has anything to do with their 2013 car it will only be the concept wich is testet. Not the exact same exhaust as the 2013 car will have.
Sorry, why could it not be the same in 2013? Are there regulation changes around this area of the car?Holm86 wrote:amouzouris wrote:i've just thought of something...autosprint says the new exhausts will look like the Red Bull ones...so about half the sidepod will be changed if it is true...if the new exhausts were indeed designed for the F2013 or what the car will be called next year..then to be compatible with this year's car then the cooling configuration must be very very similar...so is this a hint the oil cooler above the gearbox will be retained? i thought that they would go back to a regular configuration for next year for a lower center of gravity and better mechanical grip..
Exactly what you said there ... They would have to be too similar to work. But i dont believe Ferrari's next car will look so much like this years car. If it does its allready behind before the season is even startet.amouzouris wrote:no regulation changes... they are just two different cars and you cant just bolt it on and expect it to work!
EDIT: what i am just saying is that the cars must be very similar in order to easily make it work on this year's car
The traditional approach in times of relatively static regulations has been to refine the existing design. They tried to go radical this year and it didn't work. Seeing as they are still *fairly* competitive this year, I wouldn't be surprised if next year's car was fairly similar aesthetically.Holm86 wrote:Exactly what you said there ... They would have to be too similar to work. But i dont believe Ferrari's next car will look so much like this years car. If it does its allready behind before the season is even startet.amouzouris wrote:no regulation changes... they are just two different cars and you cant just bolt it on and expect it to work!
